DA 35mm macro v. 40mm v. other
Just thinking about buying a more standard prime for walk around and indoor/close spaces. I like the build and small size of the limiteds. The 35 and 40 seem pretty appealing. FOV is also nearly the same. I plan to do mostly conventional shots with occasional close up shots (flowers) and maybe some macro. Is there a disadvantage of buying a lens with macro capabilities when using it mostly for non-macro shots? Any optical tradeoffs that would make one lean towards say the 40mm non macro. If not, I would just as soon have the option for macro and choose the 35mm.
Thanks,
Mark
