07-27-2012, 04:41 PM   #1
Julie's Avatar
Normal Behavior for Takumar-A 2x Converter?
Sorry, I'm not that good with the technical names of lens parts, but the little lever, circled in red is loose... that doesn't seem normal?
What exactly does that lever control and is it supposed to be like that?
The A setting works- when I set an A series lens to A and attach it to the converter, I can control the lens aperture from the camera set in AV and through the converter.
07-27-2012, 05:17 PM - 1 Like   #2
Philoslothical's Avatar
With A type extension tubes, yes, the aperture lever is free moving when not mounted. I assume it's the same for TCs. The tension is created by the spring in the lens, and the connecting lever in the camera body. In a TC, the aperture lever is a simple pass-through, so there is no need for it to be spring loaded.
07-27-2012, 06:36 PM   #3
Julie's Avatar
QuoteOriginally posted by Philoslothical Quote
Okay, thank you very much. It makes sense because I've had M42 and non A converters that did not have a loose aperture lever, so I thought it was a little odd for this one to have it.
control, converter, k-mount, lens, lever, pentax lens, slr lens
Normal behavior for DA 21mm lens? sahale Pentax SLR Lens Discussion 10 07-08-2012 09:24 PM
For Sale - Sold: Takumar 2x Tele-converter relyt Sold Items 4 04-14-2012 08:03 PM
For Sale - Sold: SMC Takumar 50 1.4 with M42 adapter and 2x converter (CONUS) agsy Sold Items 2 09-20-2010 09:55 AM
Strange behavior from Tele-Takumar 300mm straightshooter Pentax SLR Lens Discussion 6 06-06-2010 05:56 AM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
