07-27-2012, 11:28 PM   #1
Is there such a thing as too wide?
I would like to have Pentax 12-24mm f/4 ED AL(IF)smcP-DA lens. I know it is great for landscape etc, but is it too wide for weddings. ( Groups of people, view of the church etc?) Is there a wide angle lens more suitable for me?
07-27-2012, 11:59 PM   #2
Sandy Hancock's Avatar
It might me handy in a few limited situations, but probably not worth the bother. Wedding guests in the corners of the frame might not appreciate such distortion It's also pretty big and heavy.
A fast zoom in the 16-50 or 17-50 range will give you better mileage.
If you really want something much wider for the occasional special effect, the DA10-17 fisheye is far more compact.
07-28-2012, 12:54 AM   #3
magkelly's Avatar
Unless you're doing a lot of landscapes anything wider than a 28mm is probably more than you need and there is a trade off in terms of distortion the wider you get as some have said above. I think I wouldn't mind having a wider prime than 28mm sometimes but then I actually end up just using the kit or my 28mm anyhow for that. It seems to cover it all really. But then again I'm not shooting at Yellowstone for a living or some such thing.
(My 3000th post, yay!)
07-28-2012, 01:06 AM   #4
vrrattko's Avatar
Hi Milka,
i shot my wedding with 17-70 zoom in some tight spaces....and found 17mm to be adequate focal lenght, but most shots i did were in range between 21 and 40 mm. 12-24 might be too wide, something like 16-50 will give you much more flexibility.
07-28-2012, 02:06 AM - 1 Like   #5
JohnBee's Avatar
To answer the title I'd say that when you see yourself in the pictures... you know you've gone to wide.
07-28-2012, 02:31 AM   #6
All wide angle lenses suffer from the same type of distortion. The wider you go the more distortion - that is just optics. Its the edges, and when you are shooting shots with people in them, the folks nearer the edges, may not appreciate the distortion in the lens, hence the pictures. The lenses for landscapes - churches and interiors are fine - its just when you add the people where the problems start.
07-28-2012, 05:05 AM   #7
Mareket's Avatar
It's too wide you need to break the laws of Physics to get that wide.
07-28-2012, 05:11 AM   #8
selar's Avatar
Its too wide when your feet appear in every shot.
07-28-2012, 05:19 AM   #9
liukaitc's Avatar
depend how you use and what effect you want
people even use fisheye to take great photo of people (that is way way wider than your 12-24)
07-28-2012, 07:09 AM   #10
Fogel70's Avatar
QuoteOriginally posted by selar Quote
No, no, it's only too wide when you can see the back of your head in the viewfinder.
07-28-2012, 10:29 AM   #11
QuoteOriginally posted by JohnBee Quote
Yep...the feet in the picture are not what we had in mind...
KMZ MC Zenitar 16/2.8 Fisheye on 35mm film
Of more critical importance, at least with rectilinear lenses, it the matter of distorted subjects at the edges of the frame. The lines might be straight, but the people are stretched as a result. It is almost better to be shooting (as I often do) with a fisheye.
07-28-2012, 12:16 PM   #12
Venturi's Avatar
I wouldn't use the 12~24 as my primary lens for weddings but it's certainly very useful for group portraiture; very sharp, quick-shift focusing, and I'm very fond of the colors that it produces.
I don't have any wedding shots with mine, but here's a group photo from a fashion show I shot last fall:
07-28-2012, 12:19 PM   #13
LeDave's Avatar
It's not whether it's too wide or not, it's about whether it's too wide for you or not. Can you see yourself using this lens at a weddings? Have you ever shot an event with this lens that may help you make that decision? Everybody's got their own tricks and style. Some will use a lens that wide, some won't.
07-28-2012, 01:14 PM   #14
SpecialK's Avatar
Funny thread.
If you compose properly, there is no "too wide".
The 12-24 itself not large - the hood makes it seem that way.
If you see body parts in the shot, it's your technique, not the lens.
07-28-2012, 02:05 PM   #15
Thank you so much for all your replies, I will search other options for my wide lens, although the back of my head is really beautiful, the bride will probably not like it.
k-mount, lens, pentax lens, slr lens
Not Sure If This AF Thing(and maybe the K-5)Is for Me. tabl10s Pentax K-5 37 07-15-2012 08:03 PM
Nature Same Thing applejax Photo Critique 5 11-05-2011 05:21 AM
Wide zoom or wide prime? IQ I mean thriller Pentax SLR Lens Discussion 8 07-17-2011 12:51 PM
Uh is this thing on? iluvs2ski Welcomes and Introductions 2 04-16-2011 10:04 AM
some thing that I wish for my Kx :D redeleon Pentax DSLR Discussion 8 08-01-2010 04:01 AM
All times are GMT -7. The time now is 09:02 AM. | See also: NikonForums.com, part of our network of photo forums!
