08-06-2012, 09:23 AM   #31
QuoteOriginally posted by bxf Quote
Now, I was curious to see how the "small" and "large" images compared when re-sized to the same magnification, and I got quite a surprise: the 300mm shots actually appear noticeably sharper than the 150mm shots of the same subject. This appears to be the case regardless of which direction the re-sizing is performed.
Well of course they do as the bigger ones had a higher resolution to begin with. If they were the same we wouldn't need long lenses at all. A better test is to frame a flat subject the same way at both 150mm and 300mm -- in other words stand closer at 150mm to get the same framing. Now each image starts at the same pixel resolution and you can compare apples to apples -- the 150mm will likely be sharper. (Use the same aperture.)
08-06-2012, 02:59 PM   #32
bxf
bxf's Avatar
Nothing like being confronted with the obvious to make one feel like a fool, so thanks for that Still, I'll do as you suggest, just to satisfy my curiosity.
distance, factor, k-mount, length, lens, pentax lens, sharpness, size, slr lens, subject
Sharpness, Fine Sharpness, Extra Sharpness Taviali Pentax K-5 8 03-31-2012 12:56 PM
Relationship between aperture and zoom Stardog Troubleshooting and Beginner Help 5 03-19-2012 05:11 PM
My Relationship with Pentax a Very Long Goodbye benjikan Photographic Industry and Professionals 114 01-31-2011 09:57 PM
Love hate relationship rant YossarianKL Pentax DSLR Discussion 10 09-20-2010 06:04 AM
Front to Back Sharpness: Distance setting on front of lens yoon395 Troubleshooting and Beginner Help 18 09-08-2010 04:33 PM
All times are GMT -7. The time now is 05:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
