08-03-2012, 03:31 AM   #1
K135/3.5 Blade Repair
When I move the small lever on the lens, the blades won't move most of the time. This recently started to happen. I really like the lens and haven't had it that long. It's better than the DA 55-300 indoors. Is it worthwhile to fix myself? I have never opened a lens. If the answer is a professional service, what are the best shops?
08-03-2012, 08:16 AM   #2
gofour3's Avatar
QuoteOriginally posted by pearsonbe Quote
I would send it to Eric, he should be able to fix it with a CLA.
here is his website:
Home
Phil.
08-03-2012, 11:14 AM   #3
Just1MoreDave's Avatar
The blades are always in the middle of the lens and nearly always require some disassembly. It's a less common lens so you may have to figure it all out yourself. So it may not be a great choice for the first repair attempt. If you have any small mechanical item repair experience and already have some JIS screwdrivers, go for it!
Eric should be able to give you an estimate first.
08-03-2012, 01:49 PM   #4
Ok. Thanks.
k-mount, lens, move, pentax lens, slr lens
Advice using the k135 f2.5 with the K5 everydaylife Pentax SLR Lens Discussion 17 12-27-2011 08:40 AM
Oily Aperture K135 3.5 f8orbust Pentax SLR Lens Discussion 4 07-31-2011 02:31 PM
Pentax K135/f2.5 vs Vivitar TX 135/f2.5? ducdao Pentax SLR Lens Discussion 5 12-15-2010 04:28 AM
Aperture blade repair gsr9987 Pentax SLR Lens Discussion 1 12-02-2010 03:25 AM
All times are GMT -7. The time now is 11:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
