08-04-2012, 02:28 PM   #1
Why is Helios 44m-4 more expensive than 44m?
Hi,
I would like to know why the Helios 44m-4 is much more expensive than a Helios 44m? Is there a noticeable difference in the sharpness or bokeh or something?
Bokeh is more important to me, I would prefer a swirly bokeh.
Thanks,
Nicole
08-04-2012, 02:36 PM   #2
boriscleto's Avatar
Thermisn't really any reason to get a 44M-4. There is no A/M switch so you have to gimick the pin. The 44K-4 is equivalent to the 44M-4 but is K-mount.
The other difference is that most 44M-4s are multi-coated while the 44M is single coated. If you want a lens that is multi-coated and has a swirly bokeh look for the 44-3. You have to be careful though, some 44-3s won't mount on a DSLR.
08-06-2012, 08:46 AM   #3
kent's Avatar
Today I tortured my 44M a bit (against the sun of course), so it looks like:
The bokeh is:
Not bad lens,considering the price although I heard that 44M focusing ring becomes stiffer and stiffer when using.
08-07-2012, 07:48 PM   #4
I have used both versions and saw no real difference in sharpness. I would suggest the 44M over the 44M-4 because of the A/M switch and higher blade count. As for multi-coating...unless the lens says MC, it is single coated. Like boriscleto (above), I would like to get a 44-3, but am wary of the focus ring issue.
bokeh, helios, helios 44m-4, k-mount, pentax lens, slr lens
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
Helios 44M - How to tell if MC ? Jean Poitiers Pentax SLR Lens Discussion 7 04-22-2012 12:48 PM
Can I use a Helios 44m on K-r? Eric_the_fish Pentax K-r 11 12-08-2011 03:02 AM
Helios 44M-4 needs your help... sushamyraj Pentax SLR Lens Discussion 8 10-02-2011 12:45 PM
Helios 44M-4 vs 44M teartear Pentax SLR Lens Discussion 27 08-24-2011 03:25 AM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
