08-05-2012, 08:24 AM   #1
aT0Mx's Avatar
P/K lens mount
I have a 75-205 3.8/22 with Close Focus from Vivitar.
I don't normally have a problem with any lens, but just trying to shoot the moon a few nights ago I noticed I cant get infinite focus. That's not really the problem I want to solve.
I have to use a 2x convertor (Vivitar MC Tele Convertor 2X-22) to mount the lens to my K-r because the mount is listed as a P/K.
It has this odd ring inside the mount that prevents it from going fully in to the camera mount.
Anyone seen this and know how I can either:
Take it apart and remove this ring/edge.
--or--
Use another adapter to achieve infinite focus.
08-05-2012, 08:51 AM   #2
pezmaker's Avatar
Just remove the ring. Common problem with some of these film era lenses on the pentax D SLRs - it shouldn't have any issues with older pentax K mount film cameras. This one doesn't look as easy to get off there as the other ones though, may have to take a dremel to it (after removing the metal mount from the lens...)
08-05-2012, 08:52 AM   #3
boriscleto's Avatar
Are ther any screws holding the aperture shield in place? Most lenses with the "Vivitar" shield have 3 or 4 JIS screws holding it on.
Otherwise use a Dremel to cut it off...
08-05-2012, 11:33 AM   #4
aT0Mx's Avatar
Yup, there are, and was going to take it apart, just wanted some advice before hand.
08-05-2012, 11:53 AM   #5
boriscleto's Avatar
QuoteOriginally posted by aT0Mx Quote
Just keep in mind that they are probably JIS screws and not Phillips. A Phillips head screw driver may strip them.
08-05-2012, 12:03 PM   #6
aT0Mx's Avatar
I used my fine PH00's. Worked fine.
Thanks, I'll have to try a moonshot tonight.
08-05-2012, 03:58 PM   #7
Erdž's Avatar
You could always modify the shield/flange as per this thread. I've done this previously and it worked a treat.
08-05-2012, 05:11 PM   #8
aT0Mx's Avatar
thanks, that looks like a good mod. i have the piece off and will take it to the metal shop and have them do a professional job on it.
08-07-2012, 12:58 PM   #9
aT0Mx's Avatar
They did an excellent job.
Looks like it came like that (Aside from the marker. I don't have access to anodize it.)
08-07-2012, 06:24 PM   #10
Erdž's Avatar
You still left quite a lot of that flange there. I cut mine to almost half that size.
But whatever works - as long as you can now mount it to your camera without the requirement of a teleconverter and can focus to infinity, then it's a job well done!
convertor, focus, k-mount, lens, mount, p/k, pentax lens, slr lens, vivitar
Pentax Asahi SP1000 lens adapter for k mount lens?? milka43 Pentax SLR Lens Discussion 2 01-16-2012 05:03 PM
For Sale - Sold: 4 K mount lenses and 1 M42 screw mount lens (US/CAN) alanjoke Sold Items 8 07-20-2011 06:05 AM
b4 mount to k mount? video lens on SLR? cadmus Pentax SLR Lens Discussion 6 04-23-2011 06:21 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
Change vivitar FD mount lens to K mount? meszidik Pentax SLR Lens Discussion 4 09-12-2008 09:59 AM
All times are GMT -7. The time now is 11:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
