08-08-2012, 07:36 PM   #16
capt_aaa's Avatar
Additional pix with higher Shutter speed
Here's another two shots with the same ghosting and always deviated to the left!
PENTAX K20D  Photo
PENTAX K20D  Photo
08-08-2012, 08:20 PM   #17
Hi capt
I think they are difficult shots into bright sun with the zoom nearly wide open and the reflected parts are way over exposed, maybe reflection off sensor up to front glass and back down.
You could look at the histo.
You are f/5.8 on all shots, is that wide open?
Try to stop the lens down 2 stops and leave iso and shutter same.
Then in that light, right down to f/16 and increase shutter accordingly.
08-12-2012, 06:54 PM   #18
calsan's Avatar
Did we get an answer as to what was causing this one????
I've never seen this with my 55-300 and I normally use it wide open or close to wide open (for Bird In Flight photos) even in bright sun.
I had a play with trying to reproduce this on Sunday with my 55-300 and couldn't do it.
The closest I got to seeing this sort of thing was by turning on multiple exposure mode - but then it resets to single exposure automatically after taking the shot, so it's not like you could be in multiple exposure by mistake.
If the lens is under warranty - take it to the shop where you bought it and show them the problem - maybe it's a problem specific to your lens?
08-13-2012, 02:37 AM   #19
glasbak's Avatar
Strange problem.
assuming no windows and filters.
If it happens also with non moving targets, then the lens is probably the cause.
Think of internal reflections of some kind.
If it only happens on moving targets, then it is more likely the camera.
is it movent direction related, can the ghost also be at the other side ?
Does it also happen in certain shooting modes, single shot, or only bursts (leaking shutter during cocking maybe ?)
When it is perfectly parallel to the image edges, also the transport through the ccd/cmos sensor is suspect.
k-mount, pentax lens, reflection, slr lens
For Sale - Sold: Dal 18-55 & dal 55-300 taiweitai Sold Items 9 02-29-2012 11:30 PM
Silver fa 100-300 ot the DAL 55-300? RickB52 Pentax SLR Lens Discussion 8 07-25-2011 09:53 PM
DA 55-300 at 300mm weird out of focus area dtra Pentax SLR Lens Discussion 4 03-25-2011 06:35 AM
Best Hood for DAL 55-300 cas814 Pentax SLR Lens Discussion 11 03-11-2011 04:34 PM
Weird sunlight reflection Xcessiv Pentax DSLR Discussion 10 05-04-2010 08:36 AM
All times are GMT -7. The time now is 05:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
