Originally posted by gokenin Does anyone know the distance that this lens need to be able to use the macro function from the 180-300 range? have been trying to figure it out but its been hit or miss and didnt know if that info was readily aval anywhere? thanks for any help offered
It seems like you answered your own question, or I am just misunderstanding it. It has to be between 180-300 focal length. Then you can flip the switch and it will allow you to go closer to the subject and be able to focus. If you look on the focusing ring you will see a set of numbers, I think they are yellow, that match up to the range that can only be hit when the macro switch is flipped. Basically if you are at 180-300 you can flip the switch and get closer than you would be able to otherwise.
