08-11-2012, 08:11 AM   #1
Nikon 50mm 1.4G vs SMC Takumar 50mm 1.4
Hi,
Alright, last annoying question before I start spending my money on lenses.
Nikon 50mm 1.4G vs SMC Takumar 50mm 1.4? (I'm not a nikon fan, I just saw it in a video and it looks nice, please keep your hate to yourselves. I noticed this is a pentax forum.)
Thanks!
Nicole
08-11-2012, 08:16 AM   #2
JohnBee's Avatar
You mean aside from the fact that the Nikon is AF and the Takumar is MF?
08-11-2012, 08:21 AM   #3
QuoteOriginally posted by JohnBee Quote
Yes, aside from that.. I'm mostly making videos so I won't be needing AF.
08-11-2012, 08:30 AM   #4
JohnBee's Avatar
I'm going to say that the 1.4G has much better coatings than the Tak. Other than that, it has 9 blades and the bokeh seems to be very nice as well. Though I don't think the Tak is a good match for the 1.4G myself. Perhaps an SMCP-FA 50mm F/1.4 AF Lens?
08-11-2012, 09:01 AM - 1 Like   #5
steve1307's Avatar
The video on YT by "thatnikonguy" that your probably referring to was done a Nikon D5100 with a Nikkor AF-S 50mm f 1.4 G (a $500 lens).
What I was referring to in the other thread was that you could get similar shallow DOF and smooth blurry background with really any 50mm 1.4 or even 1.7 lens which isn't too expensive if manual focus.
Its not the "Nikon lens" that make this effect its the shallow depth of field which you can get with really any large apeture lens generally longer than about 35 ish.
This includes your Tak 50 /1.4 or the K ,M, A, F or FA versions of the 50mm. or othe lengths for example 85mm f2 , 100 2.8, 135 3.5, 200 f4 all have shallow dof.
Just find one with decent smooth bokeh.
BTW the video imbedded in thread thread probably plays as 360p so I would expect your videos as captured (K-5 1080p, K-7,K-x 720p) would look much better than that.
08-11-2012, 09:01 AM   #6
simbon4o's Avatar
FA 50 1.4 is worse than the tak it is the same lens but softer wide open and with worse handling when MF. I'm thinking about this: the 1.4G Nikkor has no aperture ring, how are you going to use it? If that is not a problem for you you can go straight for the 1.8G, which is better for everything. Personally me, I like my KMZ Zenitar-M 50 1.7 in terms of smoothness of the render and low contrast, it makes such pleasing images. The Nikkor 50 1.8G has very good render too and nice swirly bokeh you can check the samples in the web.
08-11-2012, 10:42 AM   #7
Just so it's extremely clear: The Nikkor was released in 2008, so it's a modern lens. The Tak is IMHO a better choice of the two for video, for starters because the Nikon will remain at minimum aperture if you don't tape it up. It's a waste of money buying modern Nikon glass to use on Pentax bodies.
08-11-2012, 08:27 PM   #8
Just out of curiosity, what is your basis for saying the 1.4G has much better coatings than the Takumar? Have you made hands-on comparisions of the two lenses? Can't comment on the NIkon lens, haven't used a Nikon 50 since the first generation AF 1.8. That particular lens was not as good as an SMC Takumar IIRC. The SMC Takumar is very good in terms of controlling flare and internal reflections. In what way is the Nikon 1.4G better? Thanks.
08-11-2012, 08:58 PM   #9
JohnBee's Avatar
QuoteOriginally posted by John Poirier Quote
I used the 1.4G on a D700 which did quite well in broad daylight, whereas the K 50/1.4's tends to loose contrast in the blue spectrum. Aside from that, its likely tough to gauge lenses across systems, especially when were dealing with different sensors, but I concluded performance difference were likely due to coatings.
08-11-2012, 09:34 PM   #10
I used the 1.4G on a D700 which did quite well in broad daylight, whereas the K 50/1.4's tends to loose contrast in the blue spectrum. Aside from that, its likely tough to gauge a lenses performance across systems, especially when were dealing with different sensors, though my conclusion was that the contrast differences was likely due to the coatings.
Thanks. Coatings are a possibility, although I wouldn't rule out other hardware differences or software algorithms.
08-13-2012, 01:35 AM   #11
msatlas's Avatar
QuoteOriginally posted by simbon4o Quote
I think the FA 50/1.4 gets a bad rap for softness at wider apertures because so many people are using them without a lens hood. This lens needs a hood BAD. Which is why I have one. $15 for the Pentax collapsing rubber hood is money very well spent.
50mm, k-mount, nikon, pentax lens, slr lens, smc, takumar, vs
Nikon SB-25 not working using MF lens like SMC-M 50mm trunk Flashes, Lighting, and Studio 11 06-11-2012 02:53 PM
Takumar 50mm 1.4 eight element vs Takumar SMC 50mm 1.4 eight leaf Ozfreebird Pentax SLR Lens Discussion 5 02-22-2012 03:41 PM
For Sale - Sold: Pentax-F 50mm 1.7, Super-Takumar 50mm 1.4, Takumar-F 70-200mm (Worldwide) causey Sold Items 7 06-03-2011 08:06 AM
For Sale - Sold: SMC Takumar 50mm 1.4 / Pentax-A 50mm 1.7 / Pentax-M 50mm 1.4 (US) JP_Seattle Sold Items 3 09-02-2010 06:17 PM
All times are GMT -7. The time now is 05:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
