My most used lens the FA35/2...
This lens is nice and compact, extremely good opitcal quality, infact I have compared it to the 31 ltd and the only difference is in the bokeh caused by the fact the FA35 only has 6 blades... The slight difference to me isn't worth the massive price difference, but some want the best and thats fair enough..
The outer shell of this lens is plastic making it rather light weight, and it comes with a nice bayonet clip on hood.. The hood has a small cutout at the bottom (like many Pentax lenses) so you can turn a polariser without having to take the hood off..
The filter thread is the stadard Pentax 49mm, and the lens weighs in at 195gm..
The lens is also not prone to flare nor CA/PF that I get sometimes with the 50/1.4... The 35/2 is also very sharp even wide open... The AF is also very fast I guess due to its size and weight...
Overall Rating - 4.7
Construction - 5 - Small and light, I don't mind the plastic shell as it is still strong and helps keep the weight down..
Usage - 5 - Its a wonderful lens to use..
Optical - 4.5 - I can only take half a mark off here as it has only 6 blades. This means that sometimes rings of light in the bokeh are hexagons rather than round. If they had gone for more blades I would have no desire at all to upgrade to the 31 ltd (not that I can afford it or justify it)..
Some Samples
This is the best part some sample shots with this lens...
If you want any more detail let me know, will do my best to answer all questions..
