I have had the 8-16 for a bit over a day. Shot about 5 set of images, morning and evening light. Yes, I was initially disappointed with the sharpness. I expected it to be less sharp than the 12-24 but more sharp than the 10-17. What exactly that means, I still really can not say. I can say that its closer to the 10-17 at 10 then anything else. But I have found that it likes to focus lock way beyond infinity. That just skews the images and puts an additional unknown factor on the results. I have applied a +10 fine AF adjustment this morning and that has helped. That said, I don't know what an optimum result for this lens is - yet.
The more I look at the shots and understand how the lens works with the sensor, I am starting to develop an approach. This lens does take a lot of work (to understand), even if you have done a lot with a reasonable number of WA/UWA lenses. Still mulling things over, but the 8-16 lens is only for general overview scenes (my opinion for what its worth), nothing where good IQ and "standard" sharpness is going to need to be applied. For that, I need to shoot and stitch the 12-24, I think to really get what I think I want. The 8-16 has really wonderful color rendering, much closer to my 10-17. That is the one area that the 8-16 substantially beats the 12-24 right out of the box. You are acquiring this lens for its ability to take in a really wide field of view (essentially 8mm), but in doing that you are making a sub conscious trade in terms of some level of sharpness. When I say "standard" sharpness, what does that mean - I don't have a clue. The reason for this, is that this lens is so wide that there is not a uniform or linear merit to apply. For each 1 mm of width you are adding beyond what you are use to using, the field of view (or angle of view) is increased an ever larger amount. This throws your sense of proportion off - plus the beyond infinity focusing ability just adds confusion to this.
I never thought I would say this but perhaps this is where a 24MP sensor will really shine. The 8-16 essentially quickly balloons up the area that is crammed into each pixel, especially at the 8mm end. The 24MP sensor would essentially skinny this area down to approximately match that of the 12-24. So in essence, the 8-16 would probably do a lot better on a higher resolution sensor. Again just my opinion, especially since I do not have anything beyond the K5.
The 8-16's auto focuses well beyond infinity, was something that I really did not expect, and it does throw you for a loop. That coupled with the sharpness some where between the 12-24 at 12 and the 10-17 at 10, and then you mix in the fish eye vs rectilinear difference, you no longer have a really well defined reference point in which to compare and evaluate what you are observing. I still really need to figure out if +10 is the best AF fine adjustment or if some other value would be better.
Out of about 30 - 40 shots, there are a couple that have pretty good sharpness, now that I have some background understanding as to what is involved with all of this. That brings up lack of consistency. OK, shooting some in the morning with the sun coming up and in the evening with the sun going down, isn't an exhaustive test. Is it fair - to a degree - for my situation - yes, since that is how I plan to use this lens. Where I am going here, is that say you take 10 shots. If you succeed on AF lockon early, then you can have pretty good success staying on lock with out going beyond infinity. If you don't achieve that early lockon in the set, then you need to look at lens' focus distance indicator and see if you are beyond infinity - if so, manually focus back to infinity and try again. But that is just my current take of a sample of 1 lens. Is this a bad copy. I am now thinking probably not, but I think that there is sufficient tolerances involved here that you have to have a understanding of what is going on. This is an extreme lens for a rectilinear. You have to take that in to consideration. Its also a lens (that for me) with the over focus condition, presents a different situation in terms of handling characteristics.
I am starting to rethink the lenses as they apply to each of the locations I wanted to shoot. This lens is going to take a lot of work to really understand its strengths and weaknesses and to apply them correctly to the situations at hand. Would sending the body and lens to Sigma for calibration be the answer? Possibly, but I have a week and a half and I don't want to take a chance of getting everything back late and missing the window of opportunity. So, I will take this, use what I have, gain some more working experience with this, increase my understanding in terms of how to apply what I have, and run with it.
Been giving this a bit of though in terms of determining the best AF fine adjustment value. Going to take my DA 12-24 that I Really like (did I say I really like it), and at 12 mm shoot the large octillio (a big bush) mid day, lots of light on a tripod a couple feet away. Then going to shoot the 8-16 at 12, and find the best AF fine adjustment value to get the best sharpness and focus lock on. The comparison of the two lenses at 12 mm should help me keep a good frame of reference for comparison. Then see how the 8-16 performs at 8 with this AF fine adjustment value - and call it good.
