08-17-2012, 11:20 AM   #1
racingsnake's Avatar
Is my DA40 copy bad?
Hey guys how are you?
hope all is well.
well,having read raving reviews about the da40 lim i decided to go ahead and pull the trigger.
the deal was awesome - like new lens for 290$.
so i grabbed it.
went out to do some test shots and well i'm not sure i see all the hype about it being sharp.
i mean the contrast and all is there but sharpness wise my tammy 17-50 seems to produce sharper images at same focal length and aperture.
i'm going to attach a little archive of sample shots.
both my tammy and the da40 need -10 adjustment on my k-r though, while the da40 would seem to benefit from like -11 which unfortunately i can't do.
so please share your thoughts and comments.
thank you.
https://dl.dropbox.com/u/32746869/DA40.zip
08-18-2012, 03:12 AM   #2
QuoteOriginally posted by racingsnake Quote
hope all is well.
so i grabbed it.
thank you.
show me some love guys)I'm still trying to decide if it needs calibration.
08-18-2012, 03:22 AM   #3
RonHendriks1966's Avatar
I'm not going to proces on PEF's.
Is your D40 sharp when you use liveview?
08-18-2012, 03:26 AM   #4
Can you post a JPEG, with IMG tags?
Maybe full frame sized to less than 1000 px width,
and then full size crops of areas
where you're concerned about sharpness.
FWIW, the sharpness of the Tamron 17-50 is very hard to beat.
The relative advantages of primes in its range
are compactness, color, and rendering.
08-18-2012, 03:43 AM   #5
1,3, and 5 look absolutely fine. Look at the mascara and the skin texture.
2 and 4 look slightly less sharp.
I didn't check the exifs - were they all the same aperture?
08-18-2012, 04:13 AM   #6
QuoteOriginally posted by timo Quote
they are different aperture shots.unfortunately can't upload any more imaged atm as I am on call for the next 24h.
But I appreciate your input guys.
da40, k-mount, pentax lens, shots, slr lens, tammy
Bad or normal copy of DA* 16-50/2.8? jpyykonen Pentax SLR Lens Discussion 9 07-04-2012 01:36 PM
the Bad-copy paranoia, Tammy 28-75 tests volthord Troubleshooting and Beginner Help 10 06-16-2012 06:12 PM
Worry about getting a bad copy of 16-50mm lens A8YANG Pentax SLR Lens Discussion 3 05-13-2012 06:58 PM
Need help to confirm that my new K-5 and kit lens is not a bad copy kkx Pentax K-5 12 01-07-2012 02:53 PM
Jupiter 37A - bad copy? kcobain1992 Pentax SLR Lens Discussion 21 10-12-2011 07:31 PM
All times are GMT -7. The time now is 01:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
