08-17-2012, 06:43 PM   #1
Da* 16-50 - zoom ring concerns
The zoom ring seems to be progressively harder to rotate around mid ranges. Has anyone else experienced this problem or noticed a similar type of issue?
08-17-2012, 06:45 PM   #2
Mine does not do that.
08-17-2012, 07:11 PM   #3
Does yours rotate smoothly with little effort?
08-17-2012, 08:46 PM   #4
jatrax's Avatar
There is a slight 'drag' at around 28mm on mine. Just enough to notice, not an issue for me. If it is more than that you might want to get it checked.
08-17-2012, 08:59 PM   #5
liukaitc's Avatar
same with mine. can notice that around 28mm.
08-17-2012, 09:09 PM   #6
+1, I was considering getting it looked at but it's not much more than a minor nuciance.
08-17-2012, 09:22 PM   #7
Sandy Hancock's Avatar
Mine does the same. A minor increase in resistance somewhere in the middle. Not an issue in use.
08-18-2012, 03:50 AM   #8
Fries's Avatar
Same here! It is normal behavior for this lens.
08-18-2012, 05:00 AM   #9
liukaitc's Avatar
I think because of the design of 2 inner lens tubes
08-18-2012, 02:17 PM   #10
jatrax's Avatar
QuoteOriginally posted by liukaitc Quote
Agree, it starts just as the second tube begins to extend. Odd, but normal for this lens.
k-mount, pentax lens, slr lens
Should the zoom ring on my 60-250 be this tight kwar Pentax SLR Lens Discussion 9 09-07-2011 05:50 PM
Tamron 28-75 zoom ring?? COULDBE2 Pentax SLR Lens Discussion 8 03-25-2011 11:30 AM
16-50 zoom ring lurchlarson Pentax SLR Lens Discussion 2 02-26-2011 06:23 PM
Pentax DA 17-70mm zoom ring friction hyyz Pentax SLR Lens Discussion 2 11-16-2010 08:10 AM
Zoom grip decoupled from zoom ring Eruditass Pentax SLR Lens Discussion 8 11-25-2009 09:39 AM
All times are GMT -7. The time now is 02:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
