I'm seriously considering hunting for one of these but I don't expect to find one for less than $300, or probably more than $400 for a good one. There are many other lenses I could get for the same money but for various reasons I only buy Pentax A lenses and this is one I want for its super wide view without being a fisheye, and its reasonably fast aperture. Honestly if I weren't strange in the head about sticking to Pentax A lenses I would say its not worth it but consider it in that context.
I see in the reviews its fairly well rated but how much does it really do for you once you have it? I use my A24-50 F4 on the wide end rather a lot on my DSLR due to the blasted crop sensor and I find I am occationally frustrated by its semi slow speed in lower light. I REALLY like wide angle, I want the lens to swallow the whole world if possible in every picture (I think it gives a better sense of being there).
I have considered the A35mm F2 and the 28mm F2 (I wouldn't bother with the slower much more reasonably priced versions for various reasons and if I'm going with F2.8 it might as well be 20mm rather than 24mm). A15mm F3.5 is out of my price range btw.
Someone in the reviews mentioned the colors can be a bit bland with this lens?
Also why the hell would anyone pay what the MH-RB 67mm lens hood for this sells for (when you can even find it), its so flat you could use a black paper plate with a hole cut in it for the same effect. I see it doesn't appear to be outside threaded for a filter either, would a filter behind that hood cause vignetting?
EDIT: From someones review of this lens on this excellent site:
http://stans-photography.info/LongComments.html
"On the other hand, its "official" "dedicated" hood is sort of a screw-in "big round pie plate with a hole in the middle", and I do wish that Pentax had come out with a rectangular hood for this lens instead. (I don't use the hood too often on the lens, but I am able to get 75 satellite channels on it when hooked up to the TV.)"
Hysterical
