Originally posted by Boker Pretty sure my lens is limited by depth of field as with most any optic,sensor has nothing to do with depth of field no more than film does
Yes, the sensor influences DOF. Your lens has a fixed
resolution, that you can or cannot really exploit depending on your sensor (if your sensor can provide more resolution than your lens, you will see the resolution limit. If the sensor has less resolution than what your lens can provide, your picture will be limited by the resolution of the sensor).
Before we go any further, it is important to define the
circle of confusion. It goes like this : take a dimensionless point. The image of the point formed by
any lens will be a small circle, not a point. But that circle can be small enough that it will be perceived as a point nonetheless.That's when the sensor comes into play. If the circle is equal or small than a pixel on your sensor, it will be recorded as a point. If it's larger, it will be recorded as a circle. The largest circle that will be seen as a point is called the circle of confusion.
Still here?
Now, if the image of a point looks like a point, you will perceive the image as sharp. If it looks like a circle, you will perceive the image as... less sharp. Now, asyou move away from the point of sharpest focus, the image of your point will look more and more like a fuzzy circle. But as long as that circle is smaller than the circle of confusion, for all practical matters the image will still look sharp, because the circle will still look like a point.
That's the point.
So DOF is linked to the lens properties, of course, but also to the sensor.
I hope it helps.
