08-26-2012, 01:17 PM   #1
The Kellyboy's Avatar
Which M42 Adapter For My K5?
Errr...I've been looking on-line (ebay!) for a M42 - K adapter, for my K5.
Some need a tool to remove them and other don't. Some are £5 and others are £100. Which ones are best?
The only M42 lens I have is a Meyer-Optik Gorlitz Orestor 135mm f/2.8 that I found lurking and covered in dust in my dad's house.
I'd like to give it a try (great reviews on this lens), but not break the bank (or my camera!) in the process.
Ideally, the adapter would be permanently stuck to the lens as I have no other M42 lenses.
(I do have a GX-10 to 'experiment' attaching & removing first)
Any ideas?
Thanks in advance!
08-26-2012, 01:40 PM   #2
boriscleto's Avatar
Get a cheap non-flanged adapter, one of the ones that requires a tool, and remove the spring-clip. Use Loctite to permanently attach it to the lens. Cut a small slot in the base of the lens so that it engages the lens release mechanism.
08-26-2012, 01:54 PM   #3
That Meyer has no base to it at all -- just tapers to a screw. I have the Meyer 200 which is similar -- the regular non-flanged adapters will actually have a light leak and probably be wobbly if used normally. I used a Roxen non-flanged adapter (ebay, $8 I think), removed the locking spring, and put a big rubber washer on base of the lens and then screwed the adapter on. The washer ends up at an angle with just the edge down (the base is tapering, remember) and makes an excellent friction fit to keep everything snug on the camera body -- no locking needed.
That's a great lens -- hope it is good shape.
08-28-2012, 04:10 PM   #4
Lloydy's Avatar
In the UK - and abroad - try SRB Griturn for an adapter.
Other Lenses On Pentax K Cameras
These are good quality, every bit as good st the genuine Pentax items, and SRB are reliable and fast.
If the lens you have has no 'base' then I would remove the small spring clip on the adapter, and glue the adapter onto the lens with a tiny bit of engineering Loctite Thread Lock spread LIGHTLY around the thread. That will become a more or less permanent attachment, keep any light leak out and ensure that the lens will reach infinity.
Jack the Hat Photographic
Another guy in the UK to try is Jack The Hat in Cumbria, his prices aren't bad and I've had a good experience with him.
08-28-2012, 06:28 PM   #5
Does this rubber washer add some extra spacing in between the camera and lens?
I had a similar situation with a Piesker Picon where used a $2 flanged adapter and infinity was also ok.
08-28-2012, 06:52 PM   #6
QuoteOriginally posted by ultraviolet Quote
No, it is completely over the mount -- it is merely to add "base" to the lens and the non-flanged adapter is really holding it on (the washer is actually slightly too small and the lens is tapering up (getting bigger) away from the mount, so it is creating downward pressure on the non-flanged adapter holding it very securely and does the same thing on the camera body even though it is just technically a friction fit. It is very secure now and didn't have to do anything permanent. I did try a very thin flanged adapter first, but lost infinity (even though the lens does go slightly past infinity, but not enough).
08-28-2012, 07:03 PM   #7
the washer
Nice.
where to buy one from?
08-28-2012, 07:43 PM   #8
Hardware store, less than a buck. Just a rubber washer with a big hole.
08-30-2012, 01:34 AM   #9
Thanks to all of you for your input. I bought an adapter for £7 on Ebay & it works like a dream!
I just need some time to play with my new toy!
Cheers,
Matthew.
adapter, k-mount, lens, m42, m42 adapter, pentax lens, slr lens
For Sale - Sold: Pentax Mount Adapter K (M42 adapter) séamuis Sold Items 2 07-12-2012 05:50 AM
For Sale - Sold: M42 Super Taks 50/1.4, 135.3.5, Auto Chinon 28/2.8, M42 adapter,Sun 2x tele converter olivemike Sold Items 3 12-18-2011 04:18 PM
M42 Adapter stuck on M42 lenses glee46 Troubleshooting and Beginner Help 31 11-29-2011 05:16 AM
Camera mount for Pentax M42 Auto Bellows? (NOT about M42-K adapter) baj Pentax Camera and Field Accessories 9 10-24-2011 10:42 PM
For Sale - Sold: m42 Tele-Takumar 300mm F6.3 and GENUINE Pentax m42-to-K adapter (US/CAN) LowVoltage Sold Items 5 03-22-2011 05:55 PM
All times are GMT -7. The time now is 12:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
