08-30-2012, 02:33 AM   #1
bobik314's Avatar
SMC-A 135/2.8 vs Revuenon
Hello.
I bought week ago Pentax SMC-A 135/2.8. Build quality is nice, manual focus feel is the best I experienced so far, but resolution/sharpness is quite not that I expected. If I close lens to 7.1 everything is sharp.
Here are some samples took using smc-a 135/2.8 and revuenon 135/2.8 (which cost me 1/4 of pentax).
https://www.dropbox.com/sh/2v52tt84ekh4qzm/wXSSkzzX6y
Direct urls:
Revuenon @ 2.8, border
https://www.dropbox.com/sh/2v52tt84ekh4qzm/mAQHAbQ3RY/135revu2_8_border.JPG
Pentax @ 2.8, border
https://www.dropbox.com/sh/2v52tt84ekh4qzm/pfLdfbq394/135smc2_8_border.JPG
Is it normal, or my unit has flaws?
08-30-2012, 03:09 PM   #2
It is impossible to state what really caused these results. There are many many possible reasons.
But generally about these 2 lenses: a couple of years ago there was a detailed test by a German amateur tester of a range of Pentax 135mm lenses (old and new), and he used just this Revuenon lens to compare.
The site does not exist anymore, but I had downloaded the PDF.
A small exerpt of the scoring (possible maximum = best = 10, first value is the Pentax-A, second value the Revuenon):
Distortion 9/9
Vignetting 8/8
Bokeh center area 8/8
Bokeh border area 8/8
Color errors center area 5/5
Color errors border area 6/4
Resolution real life F2.8 6/3
Resolution charts F2.8 8/7
Resolution real life F4 6/6
Resolution charts F4 8/8
Resolution real life F5.6 7/6
Resolution charts F5.6 8/8
This indicates there is no area where the Revuenon is better than the Pentax-A, but some points where the Pentax-A is significantly better. But the tester resumed that also the Revuenon is one of the really good 135mm lenses.
BTW, champ of this test was the Pentax-F, second the Pentax-A (by a very small margin), probably only caused by slightly better coatings.
EDIT: The Pentax-A was in fact the SMC Pentax-A, and the better results of the Pentax-F was NOT caused by better coatings, see my posting further down.
08-30-2012, 03:38 PM   #3
bobik314's Avatar
It's the first time when I'm not fully satisfied with Pentax lens. Maybe this Revuenon is exceptionally good . Maybe someday I'll buy another A version, or something more modern. Pentax-F is quite expensive and rare, I think.
08-30-2012, 03:55 PM   #4
After reading the full text of the 26-pages review, I must apologize for a mistake in my previous posting: the Pentax-F obviously is not better than the Pentax-A because of coatings, but mainly because resolution in border areas is visibly better.
As your examples show shoots with open aperture, here a rough translation from German to English of the resuming/explaining text of the real life comparison at F2.8:
Here the Pentax-F ist the best lens. It delivers sufficient contrast and good sharpness over the complete area. Only slightly worse is the Pentax-A, which is as sharp in the center, but gets a bit softer at the borders. Third is the Takumar Bayonet 2.8 which is only very slightly worse than the 2 best lenses. Followers are the Pentax-K and Pentax-M with visibly worse resolution, mainly at the corners. The Revuenon offers visibly worse sharpness and less contrast than the K and M, and the Takumar Bayonet 2.5 is very soft and offers much less contrast than even the Revuenon.
I should also mention that the tests were done with a 10MP Pentax K200D. Resolution tests could work out slightly different with a 16MP sensor. But this can in no way account for the results you posted.
08-30-2012, 06:27 PM   #5
creampuff's Avatar
The not so common A 135mm f/2.8 delivers decent but average performance. The 4 element in 4 group construction cannot compare to the newer and optically superior F and FA 135mm f/2.8 versions. Wide open performance is soft, no wonder it is not one of the better performing A series lenses around.
08-31-2012, 12:15 AM   #6
@creampuff:
I forgot to mention that the Pentax-A in the test was the SMC version. The Takumar Bayonet 2.8/135 indeed was sold in some countries named Pentax-A 2.8/135 and had a multi coating, but not the SMC one. However, the above mentioned test showed the difference between the SMC-A and the Takumar Bayonet only with intense pixel peeping. Even the difference concerning flare was marginal. The Takumar Bayonet 2.5 suffered badly from flare - as the optical design is the same for the 2.8 and the 2.5 versions, probably the coatings make all the difference. I think Pentax improved the coatings of the Takumar Bayonet versions all the time, and the last versions were near to the SMC. The tester may have - without knowing - compared a late copy of the 2.8 with an much earlier one of the 2.5.
I would not blame too much the 4/4 optical design for inferior resolution. Some of the sharpest macro lenses use this design. If you ignore color correction, you can build 4/4 135mm lenses for FF with outstanding resolution down to F4, with not too much degrading also at F2.8.
BTW, I myself own the Takumar Bayonet 2.8, and I am very satisfied with its performance. For a while, I also owned the Porst 2.8/135, which was visibly worse than the Takumar in respect to border resolution and contrast (at F2.8 and F4) and flare. But even the Porst I would call a decent lense. It seems in the eighties there were no really bad 135mm lenses.
EDITED to add some points.
k-mount, pentax, pentax lens, revuenon, slr lens, smc-a
For Sale - Sold: SMC A 24-SMC A 35-105/3.5, 70-210/4; F 35-135/3.5-4.5; Sigma APO EX 2x TC thirdofthree Sold Items 7 02-14-2011 03:08 AM
For Sale - Sold: 3 lovely Taks - SMC 35/3.5, SMC 135/2.5 (model 2), Super 50/1.4 8 element (Wor Nick Siebers Sold Items 6 12-14-2010 01:36 PM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
