08-30-2012, 04:52 AM   #1
Moderator PEG Judges
Kerrowdown's Avatar
How wide is this?
A question for the clever ones amongst us.
I was describing my occasional method of landscape photography where I've used a tripod mounted Pentax Shift 28mm F3.5 lens fully shifted (11mm) to the left for shot 1. Then only the lens rotated 180 degrees horizontally, hence now fully shifted right for shot two, then stitch both together in Photoshop.
I was asked what equivalent wide angle does that make the final image look like? I haven't a clue or indeed knowledge of how to work that out, it's just for fun, no prizes anyone care to have a go?
I realise there will be at least two correct answers, FF and APS-C.
08-30-2012, 05:09 AM   #2
Docrwm's Avatar
Used a what?
08-30-2012, 05:13 AM   #3
Kerrowdown's Avatar
QuoteOriginally posted by Docrwm Quote
Used a what?
Apologies got called away to phone while mid edit.
08-30-2012, 05:28 AM   #4
Short answer is that you efectively get 28mm focal length on a sensor of 45.6mm by 15.7mm. Now this gives you horizontal field of view just a bit shorter than 89 79 degrees (provided that you do it on digital APS-C size camera).
If you would put a lens on APS sensor to give you similar horizontal field of view, you would need a lens of about 14.5 mm in focal length.
Since you are shifting 11mm I assume that you do it in horizontal direction, since if you wold do that in vertical direction, there would be no overlap to stich panorama right?
Well, I counted it here to be just a bit shorter than 79 degrees, but I wrote 89. Well the correct answer is just a bit less then 79
08-30-2012, 07:51 AM   #5
There are a whole lot of possible answers here. There is a web site that does provide a calculator for this, at...Horizontal Shift
  • So in the landscape orientation, as you described - 78 x 31 degrees
  • In the portrait orientation - 68 x 45 degrees
Vertical Shift
  • So in the landscape orientation, as you described - 45 x 68 degrees
  • In the portrait orientation - 31 x 78 degrees
Also as stanislav pointed out, in the horizontal shift you will need to take a third image with the lens centered (not shifted) in order to have a continuous image.
There is also yet another possibility. And that is shooting an image in the center (unshifted), then shift, and shooting an image at each clock position. This would result in an image of about 78 x 68 degrees (and note the corners would not be covered of the largest rectangle, so you would need to crop a bit smaller). This process would take 13 images, but the result is extremely large - providing about 3 times the original coverage.
08-31-2012, 12:54 AM   #6
hoanpham's Avatar
There is a calculator for your question:
Using Tilt-Shift Lenses to Control Perspective
On full frame 35mm: focal equivalent = 17.4mm
On 1.5 crop sensor: focal equivalent = 14.5mm
02-23-2013, 11:10 AM   #7
Kerrowdown's Avatar
Hey big apologies to everyone who replied to this thread, I thought I had already said thanks but can't see it here.
I'm not a rude man by nature, so forgive me, better late I guess than never.
02-23-2013, 02:23 PM   #8
QuoteOriginally posted by kerrowdown Quote
With the Samyang 24/3.5 T/S due in a couple of months,
your thread revival is quite timely.
It has a 12mm shift off-axis,
and a shorter focal length,
so will be wider than the shifty K.
02-24-2013, 01:40 AM   #9
Kerrowdown's Avatar
QuoteOriginally posted by lytrytyr Quote
Aye your right, according to the calculator link given in the thread, for FF the Samyang 24/3.5 T/S will have an Angle of View ( Horizontal x Vertical ) 102.7 x 53.1 and Focal Length if Single Photograph of 14.4 as opposed to 92 x 46.4 and 17.4 for the Pentax Shift 28mm F3.5.
The calculator also shows a couple of crop sensor variants as well, if your interested.
02-24-2013, 01:58 AM   #10
Yes, for Pentax APS-C, the Samyang 24/3.5 T/S will effectively become a 12mm rectilinear lens. Very nice!
k-mount, lens, pentax lens, shot, slr lens
Sigma super wide 24mm super wide II will not mount to K-x fuent104 Pentax SLR Lens Discussion 12 08-29-2011 11:08 AM
Wide zoom or wide prime? IQ I mean thriller Pentax SLR Lens Discussion 8 07-17-2011 12:51 PM
Help me get wide dj_saunter Pentax SLR Lens Discussion 11 12-14-2010 10:47 PM
Wide, wide Sweden (DA18-55 on an ME Super) brkl Post Your Photos! 10 06-08-2009 08:11 PM
Wide Zoom or Wide Prime....Planning Ahead joelovotti Pentax SLR Lens Discussion 25 12-21-2008 12:46 PM
All times are GMT -7. The time now is 10:38 AM. | See also: NikonForums.com, part of our network of photo forums!
