08-31-2012, 06:43 AM   #1
Pentacon 135 - which have 15 aperture blades?
Hi
I've noticed there are different versions of the Pentacon 135. Is it possible to determine which lens has 15 aperture blades by the design?
Thanks
08-31-2012, 07:12 AM   #2
THoog's Avatar
I have the 'zebra' version, which is just a relabeled Meye Orestor. It definitely has 15 blades.
10-21-2012, 03:10 PM   #3
Ive noticed that the ones which are fatter in the middle part has 15 blades.
10-22-2012, 12:30 AM   #4
hoanpham's Avatar
Pentacon 135mm f2.8 -
The older version has 15 blades.
The newer 'Pentacon Auto' has 6 blades, but semi rounded. I have the newer version. Sharp wide open, even sharper step down.
At f4, the iris still produces perfect round circle. Unless you are demanding round high ligh bokeh, and using smaller than f4, there is no point to get the older version.
Sample images, using on k20d
aperture, k-mount, pentacon, pentax lens, slr lens
so what if there IS oil on the aperture blades littledrawe Pentax SLR Lens Discussion 11 09-15-2013 08:27 AM
Sticky aperture blades ComputerControlled Pentax SLR Lens Discussion 4 02-19-2012 02:39 AM
Aperture blades beales1986 Photographic Technique 13 10-28-2011 06:45 AM
Pentacon 135mm F2.8 ~ 15 blades = BOKEH MONSTER ~ 6 blades = NOT ? minahasa Pentax SLR Lens Discussion 3 09-01-2011 06:26 PM
All times are GMT -7. The time now is 04:06 AM. | See also: NikonForums.com, part of our network of photo forums!
