01-31-2008, 09:13 PM   #1
user440's Avatar
Diagnose Lens Problem (pictures)
I have a Focal 2.8 135mm lens that I picked up on eBay some time ago, that clearly has a problem.
The front lens element appears seems to be lose in it's housing. It appears to shift within it's own vertical axis, but does not shift for or aft. Does that make sense?
I really needed a cheap 2.8 lens in this length, I would be willing to rip it apart and fix it if that is possible.
Pictures below
Thoughts?
01-31-2008, 09:32 PM   #2
Gooshin's Avatar
focusing mechanism is miss aligned, or something in the focusing mechanism is FUBAR
if this is a manual lens, go ahead and take it apart, i cant explain here whats inside, but its pretty straight forward, if nothing is bent or broken off you should be able to put it back together.
if this is an A lens with autofocus mechanisms things can get dicy
01-31-2008, 09:39 PM   #3
user440's Avatar
It is indeed manual focus.
01-31-2008, 09:42 PM   #4
Gooshin's Avatar
QuoteOriginally posted by user440 Quote
if its anything like my Chinon 50mm, its a very simple design of twin screw tubes.
think of a nut and a bolt
think of the nut as the outside of the lens, and the bolt a tube with all the lens elements in it.
they need to be properly aligned
start by taking off the rear cap and just dig in, once you get to a special set of little clips or bolts or clips that are bolted down, you should be able to completly twist the inside cylinder out of the casing
then its just a matter of twisting it back in, and securing it in the proper alignment with those same clips that were originaly preventing it from screwing out
that is.. if they are not broken.
02-01-2008, 06:02 AM   #5
user440's Avatar
Excellent input - thank you.
Every time I see these pictures, it makes me think that that I was drinking while focusing or something...
I'll rip into it this weekend, hopefully it is just a matter of tightening everything up.
Thanks again -
02-01-2008, 11:29 PM   #6
ryan s's Avatar
The first and last are actually pretty sweet...have a pinhole quality to them.
k-mount, lens, pentax lens, shift, slr lens
Problem with K10 - Green pictures arratetxu Troubleshooting and Beginner Help 10 05-05-2010 03:18 AM
HELP: *ist DL Died, please diagnose? AMBIVALENCE Pentax DSLR Discussion 18 10-27-2009 09:18 PM
Help me diagnose a lens problem germar Pentax SLR Lens Discussion 10 05-21-2008 12:16 AM
Problem - My pictures have lines Dani22 Pentax DSLR Discussion 21 01-19-2008 02:49 PM
problem posting pictures chals Post Your Photos! 1 12-12-2007 11:07 PM
All times are GMT -7. The time now is 01:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
