09-15-2012, 08:29 AM   #16
QuoteOriginally posted by jt_cph_dk Quote
Im sure that your lens is faulty somehow...
QuoteOriginally posted by gofour3 Quote
Yeah I would try another copy, mine is very sharp and does not have that issue...
My thoughts as well. These things happen. I have had a couple of lenses that should have been great, but suffered from the kinds of issues you report. In one case the issue was fungus and apparent internal film. In another, the inner elements had been scoured in an apparent attempt to remove fungus. In another, the rear element appeared to have been subjected to buffing with steel wool!
09-15-2012, 11:08 AM   #17
johnyates's Avatar
I too would encourage you to try another copy of that lens. I did a side by side comparison test--similar to yours--between my K55 and my A50 1.7. My results showed nearly identical performance between the two, with the K55 having slightly more edge sharpness at f8.
Also, I would strongly recommend, if you are serious about getting the best performance possible out of your lenses, to *always* use a lens hood.
55mm, 55mm f1.8, effect, f1.8, focus, k-mount, lens, lenses, pentax lens, pictures, series, slr lens, test
Post sample photos from soft focus filters / how to make permanent soft focus filter. slackercruster Photographic Technique 6 07-08-2012 12:19 PM
55mm soft whale Pentax Medium Format 8 10-05-2011 06:02 PM
Soft focus on SMC Pentax-DA 18-55mm F3.5-5.6 AL WR khvatov Pentax SLR Lens Discussion 7 07-29-2010 05:47 AM
For Sale - Sold: Spotmatic SP-F w/ SMC 55mm/1.8, K2, MESuper, NIB MESuper Soft Case monochrome Sold Items 9 12-05-2009 11:15 AM
Soft Lens Case for the DA 18-55mm PentaxKangaroo Pentax Camera and Field Accessories 4 01-18-2008 03:56 AM
All times are GMT -7. The time now is 05:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
