As much as I'd like to own one of those beasty expensive modern lenses with all the doo-dads (like autofocusing) I've realized that being manual seems to knock quite a bit off the price.
I currently have a Tamron AF70-300mm F/4-5.6Di LD Macro 1:2 which I've been using, and like but would like something a little faster. It also doesn't quite have to go to 300mm either.. I might be okay with a 200 or 250mm. On the low end, 50-70 is probably in the right range.
I just don't have the knowledge that some have about all the various lenses out there. But something that would allow me to go 2 or 3 F-stops down would really allow me to increase my shutter speed significantly inside.
i'm looking for something that is maybe still made or reasonably popular. Korea isn't really a pentax country. I can get a lot here, but I probably wouldn't have much luck hunting down some of these more obscure lenses.
any recommendations are welcome.
