Originally posted by lytrytyr
Stopped down to f/8,
the 18-55 will give you fairly decent wide angle coverage (below 28mm)
to tide you over on Pentax until you buy a DA15, DA21, or whatever.
Unless you're shooting bursts or fast action,
you can let the K-30 do the lens correction for you.
That is a line of thought I didn't really consider. If I want cheap wide, that is about as cheap as they get.
Originally posted by loco
Do you plan to take advantage of the weather resistance of the K-30? If so, you would want to have at least one WR lens. The 18-135 is a fine choice for that if you only plan to have one WR lens since it has such a nice range. There is also an 18-55 WR lens. The Pentax 18-55 isn't the greatest lens (it is a kit lens, after all) but it's better than most kit lenses.
It's nice to have a walkaround lens and that's what I use the 18-135 for. However, if you don't anticipate the need for that, then the 35/2.4 is a fantastic lens and a great value for the price.
The 50/1.8 is not weather resistant as far as I know.
I would like the ability. It is a shame the kit lens isn't the WR version or I would not even ask this question. I want to get back into street in NY so the added durability is nice if I want to grab the camera without a bag and it starts to pour. I was considering getting the body only and the 18-55 wr separately but it is a lot of money that way.
Originally posted by msatlas
When I first started with a Pentax DSLR, I went straight past the kit lens and got a Tamron 17-50/2.8.
The DA 35/2.4 and 50/1.8 are both really nice optically and give a lot of bang for the buck.
I think if (when) I get a fast normal zoom I will go Pentax, unless that MAP Crap doesn't subside.
I think when you buy into a system you need some sort of lens roadmap. A 50mm is cheap and needed, I would like a normal lens which on APS would be the 35 (I one day want to own the 31mm limited but oh boy is that a lot of cheddar). I would probably then save up for the DA* 16-50 if the price stays sane. Then maybe a medium tele. Work my way up from there.
