09-14-2012, 04:28 PM   #16
KHatfull's Avatar
I thought about that and agree, but don't they tab into a ridge into the F and FA lenses?
09-14-2012, 08:47 PM   #17
Try stacking step-down rings. I haven't owned the A 50/1.7, but have had the FA, F, and M (currently) equivalents. On the F and M, I've used a 49-37 and then 37-30.5 step down ring stacked, with a cheap snap-on 30.5mm lens cap. This did not cause vignetting, was cheap, worked great as a hood and lens protector, and is more compact than most hoods.
Brandon
09-14-2012, 11:01 PM   #18
QuoteOriginally posted by bpv_UW Quote
Try stacking step-down rings....
No need to stack. A 49-28mm works great. The lens in the photo is FA50 F/1.7
Here's a 49-28mm on a D-FA 100mm macro:
09-15-2012, 09:17 AM   #19
Professor Batty's Avatar
I've used a metal hood from a Takumar 135 with my 50mm f1.7 - it is the same as the metal hoods on ebay, but is 50mm deep. It works fine, no vignetting.
09-16-2012, 12:48 AM   #20
bricamry's Avatar
QuoteOriginally posted by SOldBear Quote
oh sir... it is great... i have crazy rubber hood from mid-format and it is crazy... i have A50/1,4 ... shall i buy 49-28 step-down ring? it will work without vingeting on asp-c? even with filters in it?
09-16-2012, 03:37 PM   #21
QuoteOriginally posted by bricamry Quote
I sold my A50 F/1.4 before I had the idea of using step-down rings so I can't tell for sure if it works without vignetting. But a 49-28 adapter works with an F28 F/2.8 (photo below), so it should work with an A50 F/1.4. If not, a 49-37 + 37-30.5 should work (I haven't been able to find a 49-30.5).
09-16-2012, 09:08 PM   #22
bricamry's Avatar
cool, very thanks... with step down rings is isue, tahat nobody sell it... but it seems as beter solution than hood.
i have plus one issue, i am using reduction 49-58 and 58mm filters... it is awesome... a must buy many rings ...
I will be lord of the rings!
... the shipping of the ring... the two lenses.... the return of the hood...
09-17-2012, 04:15 AM   #23
Na Horuk's Avatar
That photo.. your gear.. what have you done to it! You are like Dr. Frankenstein!
hood, k-mount, pentax lens, slr lens
Quick Lens Comparison (Voigtlander 58/1.4, A50/1.7, A50/2.8 Macro) jeffshaddix Pentax SLR Lens Discussion 25 06-09-2014 04:29 AM
For Sale - Sold: Auto Chinon 35/2.8 (M42 mount), A50/1.7, & A50/2 indytax Sold Items 6 09-03-2012 05:41 AM
For Sale - Sold: Three Outstanding Pentax-A Series Lenses; A50/1.4, A50/1.7, A100/4 macro dgaies Sold Items 12 08-26-2011 05:57 PM
New AL 2 kit vs A50 1.7 vs A50 2.0 TourDeForce Pentax SLR Lens Discussion 3 04-20-2008 08:29 PM
All times are GMT -7. The time now is 03:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
