09-17-2012, 04:47 AM   #1
DIY tilt/shift lens for Pentax K?
Has some one done T/S for K mount?
What I've understood is that focal length should small for more perspective pictures and drawing circle should be larger than in normal lens. So what is minimum for T/S in APS-C sensor?
May K/M 24mm F2.8 be good cheap alternative or should it be medium format lens?
09-17-2012, 06:09 AM   #2
Na Horuk's Avatar
I think most people use 645 or 67 lenses, or Pentacon six lenses with a tilt shift adapter. I think there was a thread on someone making one on these forums. He used two mounts, strings, and a pinkponk ball I think. You might try making your own bellows, but it is rather hard to make a T/S thingy with good control over the tilting and shifting - usually it becomes impossible to be used hand held.
09-17-2012, 06:11 AM   #3
SpecialK's Avatar
It is not DIY...
Samyang 24 mm F3.5 ED AS UMC Tilt/Shift Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
09-17-2012, 06:30 AM   #4
The problem with using a medium format lens is that a 24mm is a fisheye, which is not ideal for tilt-shift because of the curved focal plane.
09-17-2012, 08:30 AM   #5
QuoteOriginally posted by elliott Quote
The D( F)A 645 25/4 is rectilinear.
09-17-2012, 11:13 AM   #6
hoanpham's Avatar
You still can use old nikon ultra wide with shift adapter on nex or m4/3.
There is a kipon made shift adapter, but no K mount yet.
I use shift lenses with tilt adapter on nex, or tilt only for regular lenses, pentacon six on pentax slr.
09-17-2012, 11:54 PM   #7
Price going to be? 1000$?
09-18-2012, 01:21 AM   #8
hoanpham's Avatar
No idea about price. But canon/nikon TS lenses are far more expensive.
1000usd sounds too cheap.
pentax K 28 shift ~700usd
nikkor 28 PC ~ 800usd
olympus OM 24 shift ~1500usd
anyway, 1000 is a expensive toy if you don't really need it. I found 28mm in crop sensor usable.
Shift: as wide as possible
Tilt: any focal length. Very use full.
Here is a sample from nikkor 35/1.4 with tilt - sharp all the way, all text can be read on 100% crop:
Another sample from pentax A 50/1.2 at f1.2 - almost dark, but note the focus plan - sharp all the way:
and using TS as portrait, from nikkor 28PC, shift up 2mm, tilt right, focus plan is on both eyes, note the bokeh:
09-18-2012, 02:20 AM   #9
QuoteOriginally posted by hoanpham Quote
In this topic I'm looking for very cheap DIY options like these when absolute usability or IQ is not the point but fun is.
09-18-2012, 02:57 AM   #10
hoanpham's Avatar
Nice link of DIY options.
I tried once, but whatever I try, it's not as good, due to several factors:
- The focus plan is sensitive with the angles. A slightly movement will make the intent subject out of focus.
- Dust to sensor
- Infinity issues
and I spent too much time. the material cost became high in the long run after many tries, with a non reversible mod.
k-mount, lens, lens for pentax, pentax lens, slr lens, t/s
Upcoming Samyang 24mm f3-5 Tilt/Shift Lens interested_observer Pentax SLR Lens Discussion 38 09-07-2012 08:22 PM
645 or 67 lens to be used w/ tilt shift adapter? gsrokmix Pentax SLR Lens Discussion 9 07-28-2012 05:11 PM
Possible to make a tilt shift lens out of a 50mm on a crop sensor? Abstract Pentax SLR Lens Discussion 10 02-07-2011 03:47 PM
Wanted - Acquired: HARTBLEI 65mm Super-Rotator Tilt Shift Lens for Pentax K Ishpuini Sold Items 2 07-15-2010 04:43 AM
35mm and 80mm tilt shift lens for Pentax High Roads Photo Photographic Technique 6 09-07-2008 03:41 AM
All times are GMT -7. The time now is 08:58 AM. | See also: NikonForums.com, part of our network of photo forums!
