02-02-2008, 07:45 PM   #1
New to Pentax - CA, PF
I'm really surprised at how badly the 31mm Limited controls CA. The lens is everything it's talked up to be, as far as sharpness and build quality, but in situations where my old Nikon D70+Sigma 30mm f/1.4 shows very little chromatic aberrations (but is otherwise unappealing), the K10D and 31mm has rather noticeable color fringes.
I've searched the forums, and apparently CA affects all Pentax lenses to some degree, but how much is too much? Has anyone bough a 31mm Limited, thought the CA was excessive, exchanged it and got a new one that was better? The really unhappy thing is that I also have a 77mm Limited, but I'm afraid to open the box...
-T
02-02-2008, 07:58 PM   #2
Lowell Goudge's Avatar
QuoteOriginally posted by twinda1 Quote
-T
How about an example?
Show us what you think is unacceptable.
BTW all lenses will have fringing in out of focus areas. it is not limited to pentax
02-02-2008, 08:20 PM   #3
Ole
Ole's Avatar
I haven't noticed any color fringing in the several hundreds of shots I have made with my 31mm.
02-02-2008, 09:33 PM   #4
Example attached
Hi, thanks for the quick replies. I've attached a 100% crop -- the fringing is definitely in the out of focus area in the eye and also along the face. Shot wide open. I'm pretty sure I haven't noticed this type of fringing on the Sigma 30mm and D70 combo. It's possibly the K10D too though -- reidreviews.com has noted CA for the 3 or so lens tested so far with the K10D.
-T
PENTAX K10D  Photo
02-02-2008, 11:19 PM   #5
aegisphan's Avatar
That's not too excessive. You can correct it quite easy. Anyway, from my personal experience and reviews from other sites (e.g. 16-9.net on the 85mm comparison), Pentax does have more CA issue than other brands. I recently did a comparison between the 31 and the Distagon 28. The 28 had very minimal amount of CA even at wide open, while the 31 at 2.8 still had more CA. This was in extreme condition (sunlight directly on white surface). I found that if i stopped my 31 down to f5.6, the CA was gone. CA is not a major problem to me since i can somewhat control it with post processing.
By the way, that's a lovely picture. I like it.
02-03-2008, 09:16 PM   #6
QuoteOriginally posted by aegisphan Quote
Thanks, even with the fringes, I'm liking my results so far. I highly doubt they're visible on smaller prints.
02-04-2008, 01:48 PM   #7
TKH
TKH's Avatar
QuoteOriginally posted by Ole Quote
I have noticed a lot of color fringing in the several hundreds of shots I have made with my 31mm. This was one reason to change my lenses from FA to DA. Now Im very happy.
See also this thread: lose your respect
My personal look of view is:
On my K10D the three DAs are
- quicker AF
- smaller
- lighter
- exposing is correct
- mutch less CAs
- have quick shift
I really know that a mutch better photgraph than me will perhaps take mutch better pics from using the FAs instead of using the DAs. But with my little photographic scills, the DA will work better.
Rainer
02-04-2008, 09:30 PM   #8
Now this a little excessive, no? It's a pretty high contrast situation, so if it fringes, so be it. I'm trying to determine if I have a bad sample of either the 31 or K10D -- unfortunately both are new. What do you all think?
PENTAX K10D  Photo
02-04-2008, 09:47 PM   #9
SpecialK's Avatar
Looks like my old Opteka conversion lens :-(
And also like a used 300mm f/4 Pentax I had for a week and returned (but that was only $99).
02-05-2008, 03:59 AM   #10
The CA on the edge of that ear is rather bad. However, the outer lobe of the ear is/is just about totally blown out. That's pretty provocative to a shorter focal length (if my experience with the SMC Takumar 35mm is anything to go by). If you shot that in RAW, I'd try a bit of exposure compensation, maybe on just the ear (process twice, once for less exposure, then a layer mask in Photoshop). The CA green fringe can be reduced in pp in several ways, as well (I like the selective color/color replacement trick). Good luck, and watch out for those blown highlights!
Last edited by christinelandon; 02-05-2008 at 04:02 AM. Reason: clarification and comparison
02-05-2008, 05:05 AM   #11
Chromatic Aberrations (CAs)
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are very low for a wide angle lens. The issue shouldn't be really field relevant with an average pixel width of 0.4px to 0.6px at the image borders. You can force the lens to produce some mild purple fringing (color blooming) at large aperture settings and in extreme contrast situations. (Emphasis added)
the EXIF shows the first picture is shot at f1.8 and the second at f2.
Courtesy of Pentax Lens Tests
02-05-2008, 05:10 AM   #12
wlachan's Avatar
I think it's normal for this lens. I have noticed the same green CA even on film. However, I have found it happens only on OOF areas. Recently I took 3 identical shots on tripod and 2 were with this same green CA, but surprisingly the 3rd one was free of it. I have no explanation of it however.
02-05-2008, 05:30 AM   #13
blende8's Avatar
This is longitudinal CA (aka "fringing") and it looks pretty normal to me.
I think you have to live with that.
Or you have to buy the very expensive Leica lenses, which are known for their outstanding chromatic correction.
You may want to look at my recent test of the Voigtlander 40/2:
Voigtlnder Ultron 40/2.0 vs Pentax FA 35/2.0
If you scroll down a bit, you will see some CA examples from this lens.
The FA31 will very probably look similar.
31mm, k-mount, pentax, pentax lens, slr lens
All times are GMT -7. The time now is 05:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
