09-24-2012, 12:41 AM   #1
From DA35mm 2.4 to DA35mm 2.8 Macro
Hi,
I have been in love with Plastic Fantastic already for quite a while and have taken a lot of great pictures. Now I have a reasonably good offer to upgrade to 35mm Macro lens and am bit challenged - how much of an upgarde that would be?
For me 35mm suits very well and I like to get close and shoot details, elements and other interesting stuff. So from that perspective Macro would suit me (no need for insects), but... I am also making amazing close ups with DA 35mm 2.4.
Has anyone gone that route or owned both? I would appreciate any comments.
Superdavis
09-24-2012, 01:31 AM   #2
gtl
The DA35mm macro is a fantastic lens to me. But it rarely gets used after I got my FA31mm. Problem with the DA35mm macro is that it does tend to hunt, and its focus throw is very long. If you can live with the slower AF, by all means change. The close up focus ability is fun.
Do note its also slightly slower, and it won't cover the FF image circle like the DA35mm f2.4 does.
09-24-2012, 01:35 AM   #3
QuoteOriginally posted by gtl Quote
Yes, close up is really fun. I have DA 10-17 that can focus up to 15cm and I love it. DA 35 Macro have the same distance compared to DA 35 F2.4.
FF no issue here for me, and also AF speed is relative measure. For what I would use it does not matter.
by all means change
Tempting, tempting
09-24-2012, 03:24 AM   #4
It's a Ltd, so construction, etc, is superior. It has quick-shift, and a built in lens hood.
Macro is good, but you need to get really close, so not much good for fauna and flora, but great for still life
09-24-2012, 03:33 AM   #5
Clavius's Avatar
The 35 ltd has proven to be lots of fun for me. Superdavis is correct in comparing it with the DA 10-17. The close focussing distance adds a lot of flexibility, and not only for macro. The 35 ltd can actually focus on waterdrops on the front element. It's ultrasharpness is also very welcome, but I don't know how it compares to the DA 35 2.4 though.
And yes, a focus limiter would have been really very handy for this one!
09-24-2012, 03:38 AM   #6
Bob from Aus's Avatar
i only have the 35Ltd. The hunting is not much of an issue as usually I am using it for something that remains still. Users of the alternative seem to love their lens.
I use my 35Ltd often as my walk around lens. It gets a a very good workout for macro when the subject does not want to escape. as a 35mm macro it has much better depth of field compared with my 70mm and 100mm macros so I tend to use it for wildflowers when I am not using flash.For a small lens it has a magnificent punch. Its price is significant so unless you are going to use it a lot or want the macro then you should save your dollars and buy the plastic fantastic.
A comment about a focus limiter. My sigma 70mm has one. I am sure it adds to the size and weight of the lens. My 70mm stays mostly at homes as it is such a chunk of extra weight.
09-24-2012, 04:03 AM   #7
QuoteOriginally posted by JohnX Quote
That's exactly my type of usage
QuoteOriginally posted by Clavius Quote
Ouch, the waterdrops sound promising DA 35 2.4 is also very (amazingly) sharp and they are quite matching in centers, but test would give 35 Macro bit better corner sharpness.
QuoteOriginally posted by Bob from Aus Quote
I have the plastic fantastic already and use a lot, so that's where the dilemma is - to upgrade or not to upgrade and is it an upgrade at all?
09-24-2012, 04:14 AM   #8
Clavius's Avatar
QuoteOriginally posted by superdavis Quote
Ouch, the waterdrops sound promising.
Yes, watch that front element during composing! Or just shoot with both eyes open. This goes for the DA 10-17 too, as you probably know. It's very easy to get really close to your subject when composing with that close focussing fisheye.
Well, it seems like you really appreciate the added versatility and close focussing feature of the DA 35 ltd. And it seems like you don't mind it's only downside: the slow AF because of the long focus throw. Sounds like an upgrade to me.
Concerning the macro function and getting to close to bugs. Yes, it does take some more patience, but it's absolutely not impossible. I've managed to shoot hovering flies in flight with the DA 35 ltd. Of course, if shooting shy bugs is your main concern then this lens isn't for you.
09-24-2012, 04:38 AM   #9
Well, it seems like you really appreciate the added versatility and close focussing feature of the DA 35 ltd. And it seems like you don't mind it's only downside: the slow AF because of the long focus throw. Sounds like an upgrade to me..
Sounds the same to me: 15mm closer focus + 1:1 + Quick/Shift (I love it on my other DA lenses) + slight IQ improvement + 3 more blades (hopefully better Bokeh)
09-24-2012, 05:24 AM   #10
That depends on how you approach your subjects:
The bokeh is good in the macro range, but can be nervous further out.
09-24-2012, 06:15 AM   #11
QuoteOriginally posted by lytrytyr Quote
This is what I have read, and was making me think this over, but .... I guess also Bokeh is something of Like/Dislike type of things and there is no Ultimate Truth
09-24-2012, 06:34 AM   #12
My compliments! Butterflys are normally long-gone before I'm even within just a few feet of them!
09-24-2012, 07:18 AM   #13
TER-OR's Avatar
I'd be tempted to get a longer macro for added flexibility. Unless you really like to get that camera close to the subject, a 50mm macro might be more useful.
09-24-2012, 07:34 AM   #14
QuoteOriginally posted by TER-OR Quote
Reasoable point! Keep the DA 35 2.4 as all allrounder and get longer 50 or 100 Marco was my initial idea, but somehow I thinkg I would loose walkaround flexibility - guess this was the reason I thought about DA 35 Macro
09-24-2012, 07:47 AM   #15
TER-OR's Avatar
The 100mm is not a great walkaround lens - unless you're like me and are walking around taking pictures of bees to submit for the bee survey... It's a decent telephoto, though I'd rather have the 55-300 for that walkaround daytime lens. That said, you can have my FA100 macro when you pry it from my cold (or charred) dead hands.
A 50 might be a good compromise. I'd keep a watch on the marketplace for an FA 50 macro. I'd think you can likely sell it for about the same if you don't like it.
da35mm, k-mount, macro, pentax lens, slr lens
For Sale - Sold: FA77mm/1.8 and DA35mm f2.8 Macro Limited matoqui Sold Items 7 06-17-2012 06:18 AM
Lens cap and filter for SMC DA35mm Macro Ltd xanis Pentax Camera and Field Accessories 2 05-01-2011 01:40 PM
Upgrade from FA35mm F2.0 AL to DA35mm F2.8 Macro Ltd? aaronius Pentax SLR Lens Discussion 8 01-20-2010 07:35 PM
For Sale - Sold: [EU] Trade DA35mm/2.8 Macro Ltd with DA70mm/2.4 Ltd celetron Sold Items 6 06-23-2009 10:14 PM
All times are GMT -7. The time now is 05:34 PM. | See also: NikonForums.com, part of our network of photo forums!
