09-25-2012, 12:29 AM   #1
romansolar's Avatar
Fact or Fiction _ Sigma 18-125mm f/3.5 DC OS HSM Pentax
Hello folks
i dont like changing lenses so often. And during my photo trips i am changing them often
pentax 18-55, and 50-200
So i am thinking i could buy Sigma 18-125. I found some markets and i am little bit confused. If someone could help and answer few questions, that would be so great!
appreciate so much
1)
Sigma 18-125mm f/3.5 DC OS HSM Pentax is fake? F/3.5 for 18-125? Its mistake? Should it be 3.8-5.6 or something? Because just 3.5 seems like fast lens
2)
Why i found Sigma 18-125mm with these different aperture values?
f/3.5
f/3.8-5.6
f/3.5-5.6
09-25-2012, 01:17 AM   #2
Fogel70's Avatar
There is two version of Sigma 18-135mm lens, an older discontinued version (18-125mm F3.5-5.6 DC) and a newer version (18-125mm F3.8-5.6 DC OS HSM), but the newer version do not include optical stabilization for Pentax.
Sigma has information on their lenses easily available at: Sigma Lenses Overview | SigmaPhoto.com
09-25-2012, 01:58 AM   #3
romansolar's Avatar
thanks Fogel!
so older version does have OS?
Which multipurpose lenses from Sigma have OS for pentax mount? Is there any?
09-25-2012, 02:34 AM   #4
Fogel70's Avatar
QuoteOriginally posted by romansolar Quote
thanks Fogel!
The older version of 18-125 is without OS on all mounts.
Check specifycation on each lens on Sigma site, and you will find which one have OS for Pentax (or you can use the "lens finder" function on Sigma site).
09-25-2012, 02:35 AM   #5
It appears that there is this lens - I would suspect that Sigma does not feel the need to include optical stabilization in the K mount lenses since Pentax has in-body shake reduction. If the lens has stabilization, you would only use either the in-body or the lens, but not both. If you were to use both, they would each cancel out the other. If you were to use both, the lens would sense the movement, and move the lens elements to cancel the movement thus stabilizing the light on the sensor. If the in-body shake reduction were also active, the in-body SR would sense the movement (the same movement sensed by the lens) and move the sensor in order to negate the movement - however since the light was essentially stabilized by the lens, the movement of the sensor essentially adds the movement back in thus counteracting the action of the lens. You would need to turn one of them off (OS switch on the lens or turn SR off in the body).
09-25-2012, 03:23 AM   #6
romansolar's Avatar
ouch, really
someone told me that its great to have body with stabilization, because i can use lens without OS, but also i could benefit from having OS lens and also body stabilization
hmm, strange. So new lenses for pentax are always without OS?
thank you guys for response
ps: i also thought that OS lens is better then body stabilization
09-25-2012, 04:14 AM   #7
Fogel70's Avatar
Sigma seems to have changed their policy a few times over time.
- At first they made two different versions of the lens, one more expensive version with OS, and a cheaper version without OS. OS version of the lens was only available for CaNikon.
- Then they made one version of the lens including OS for all mounts.
- Now they make one version of the lens, but remove OS function for Pentax. And Pentax user have to pay the same price as on OS version, and the size of the lens is bigger than it has to be.
09-25-2012, 05:18 AM   #8
romansolar's Avatar
Thanks Fogel!
i would like to know your opinion, should i look for multipurpose zoom lenses from different company? because looks like there is no reason to buy OS lens
Roman.
09-25-2012, 05:52 AM   #9
Fogel70's Avatar
IMO the best budget choice is a used Pentax/Tamron 18-250. Small size, good IQ for this type of lens and cheap.
SMC Pentax-DA 18-250mm F3.5-6.3 ED AL [IF] Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
09-25-2012, 09:33 AM   #10
romansolar's Avatar
thank you for your suggestion
09-25-2012, 07:18 PM   #11
Although more expensive, if you can wait you might want to consider the not-yet-released 18-250 sigma - or at least wait to read some comparative reviews of it.
Paul
09-26-2012, 12:02 AM   #12
romansolar's Avatar
thanks Paul, will consider it. I would like to have new lens as soon as possible but i am not gonna buy it today.
09-26-2012, 01:01 AM   #13
I wish Pentax or Sigma DID in fact make a 18-125mm f3.5 or even a f4. Or better a 2.8. Would be a great gig lens.
Something akin to the Canon 24-105 f4L or Nikon's 24-120mm f/4.
Or Pentax should just do an AF update of the A 35-105 f3.5. That would be cool.
dc, dc os hsm, f/3.5, hsm, k-mount, pentax, pentax lens, sigma, slr lens
For Sale - Sold: Sigma 18-125mm f3.8-5.6 with HSM (very fast AF) Quazimoto Sold Items 4 09-19-2012 02:15 AM
Wanted - Acquired: Sigma 150-500mm HSM, 150mm MACRO HSM, Sigma 18-250 HSM, Sigma 10-20mm HSM mackloon Sold Items 7 05-01-2011 02:25 AM
Sigma 18-125mm f/3.8-f/5.6 HSM elg Pentax SLR Lens Discussion 5 01-08-2011 06:10 PM
Sigma 18-125mm 3.8-5.6 HSM? brofkand Pentax SLR Lens Discussion 9 10-28-2010 12:31 PM
Out-resolving, fact or fiction? rdrum76 Pentax SLR Lens Discussion 20 01-24-2009 10:47 AM
All times are GMT -7. The time now is 03:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
