I read some very similar threads to this, and I have accumulated some good info on this now, but I was hoping to find a bit more advice specific to myself. I'm thinking about getting into
Much of the recommendations seemed to point to two specific lenses...
The Pentax 15mm ltd, and the Tamron 10-24.
Now, the way I see it, the Tamron 10-24 has the advantage of being wider, and going to 24, which may limit the fisheye effect a bit, when the room is available. It also has f/3.5 as opposed to f/4. It is also currently $200 cheaper. That's nice. I'm not opposed to saving money
I also have a DA 40 ltd, I think that might work for outdoor shots when I have enough room. That's a fantastic little lens. Would that complement one of the above lenses?
If so, would those two be a pretty solid lenses?
I will also hopefully be adding a K-5, or K-5 Mk II, the K20D will be a backup/secondary camera for the same purposes.
And possibly flashes, would those be necessary for real estate work? If so, which ones would work well?
Thanks everyone!
