10-10-2012, 07:39 AM   #16
QuoteOriginally posted by isb.deep Quote
albeit an external one with a HSS mode. Otherwise the shutter speed would be stuck at 1/180. I tried the water droplet photos sometime back with a Fuji HS10 that I used to have and they came out okay. The advantage of having an electronic shutter, I guess. You can sync flash, even wirelessly, to upto 1/2500 second.
With low ambient light you don't need HSS, the flash is what freezes the motion, not the shutter speed. A flash at low power can effectively give you 1/20,000 second exposure, even if the camera is at 1/180.
10-10-2012, 08:10 AM   #17
Good point!
QuoteOriginally posted by elliott Quote
I was thinking more like shooting in normal daytime ambient light but ofcourse, you are correct. That will put in things in a new light for Sachin, I am sure. Sorry for the bad pun
10-10-2012, 01:24 PM   #18
Correct. This is where it all started: April 6, 1903: Edgerton Born, Father of High-Speed Photography | This Day In Tech | Wired.com
10-11-2012, 07:51 PM   #19
QuoteOriginally posted by John Poirier Quote
Interesting article. Thanks guys. Let me try it. I will post samples if it comes out really good.
camera, copy, da, help, issue, k-mount, lens, pentax lens, slr lens
Bad copy of a DA 15mm Limited? sinjin Pentax SLR Lens Discussion 16 09-05-2012 02:20 PM
Is my DA40 copy bad? racingsnake Pentax SLR Lens Discussion 5 08-18-2012 04:13 AM
Bad or normal copy of DA* 16-50/2.8? jpyykonen Pentax SLR Lens Discussion 9 07-04-2012 01:36 PM
Need help to confirm that my new K-5 and kit lens is not a bad copy kkx Pentax K-5 & K-5 II 12 01-07-2012 02:53 PM
Jupiter 37A - bad copy? vladimiroltean Pentax SLR Lens Discussion 21 10-12-2011 07:31 PM
All times are GMT -7. The time now is 06:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
