10-05-2012, 03:11 PM   #16
Docrwm's Avatar
Fastest and widest - zooms are your friend in tight spaces and when you are not alone to focus exclusively on your photography.
Sigma 18-50 f/2.8 + DA15 + DA70
10-05-2012, 03:15 PM   #17
THoog's Avatar
When Discovery first arrived, I did a couple hours with the DA 10-17 fisheye (and I have the purple fringes to prove it! )
Discovery tail fisheye view | Flickr - Photo Sharing!
Discovery tail fisheye view B/W | Flickr - Photo Sharing!
Since then, I've been digging into ultra-wide-angle with the Siggy 10-20. It's all fun.
10-05-2012, 03:21 PM   #18
SpecialK's Avatar
Take the 15. You can get close. Just for reference, this is the 12-24 @ 12mm, 1/30, f4.5, ISO 800.
Same info, except 1/45.
21mm.
10-05-2012, 05:20 PM   #19
msatlas's Avatar
I'll just add on to the number saying definitely bring the 15. That plus the 35, 40 or 43. That second choice is the hard part!
I would probably pick the 35 since it's nice & sharp but you can also blur the background enough for portraits.
You certainly couldn't be faulted for bringing the 40 for absolute tinyness.
10-05-2012, 11:19 PM   #20
Laurentiu Cristofor's Avatar
I recently went to a couple of air museums (Evergreen and Tillamook). One was bright and I could use f/4 - f/5.6 most of the time, the other was dark and an f/2.8 lens would have only been usable with a tripod. So if you can find out what apertures you can use, that should help you figure out the lenses to take.
As for focal length, keep in mind that you can stitch images. I did this with the Tamron 17-50@17mm to capture the Spruce Goose in 4 shots with the K-7:
10-06-2012, 07:53 AM   #21
Docrwm's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
Nice photo of the Spruce Goose! I had wondered what became of that oddity. Glad to see it preserved and I really like that they parked a C-47/DC-3 Gooney Bird under its wing - talk about adding perspective to the shot
10-06-2012, 09:53 AM   #22
QuoteOriginally posted by Docrwm Quote
Thanks!
Stitching is a great choice. I kick myself for often forgetting about it. But it is interesting, because if you have one sharp prime, you can crop if you need tighter compositions and you can stitch if you need wider ones, so it becomes easier to rely on a single prime lens.
10-06-2012, 10:51 AM   #23
Docrwm's Avatar
Thanks!
I've never stitched photos together. I have LR3.6 and PS5 but haven't ever even played with that feature, or is there better software for that sort of thing?
10-06-2012, 04:58 PM   #24
I concur in wide and fast plus practice your slow shutter technique. You might be amazed at what you can do with some practice.
10-06-2012, 05:32 PM   #25
ihasa's Avatar
Looks like you could practically get away with the DA15 only! Good points re stitching above - allow plenty of overlap and the DA15 will work fine for stitch shots. I use microsoft ICE, which is very effective I find. Your shots will assume an almost fisheye quality because your viewpoint is rotated.
10-06-2012, 05:40 PM   #26
Docrwm's Avatar
QuoteOriginally posted by ihasa Quote
Thanks for the ICE reference, it has the benefit of being a free download I discovered.
10-06-2012, 08:03 PM   #27
Just1MoreDave's Avatar
I use Photoshop CS5 for panos. In Bridge, I slelect all the images first, open in ACR, set them all to the same white balance. Then I use the lens correction tab if my lens has a profile, then click Done. Then back in Bridge, Tools -> Photoshop -> Photomerge. You can choose different projections there. I just let the program pick everything the first time. With good shots to begin with and an uncomplicated subject, the auto settings work fine for me, so I rarely go back and try something else. I don't know whether the lens correction step is necessary, it might happen automatically.
All my panos so far are handheld or use some improvised support, so the stitcher has some work to do. I do turn off all Auto settings before taking the shots. I use viewfinder markings like the brackets to keep track of overlaps.
Here's one that is sort of a failure, taken in the McDonalds restaurant in the Udvar-Hazy museum. I had to do some editing because people were moving from shot to shot, and Photomerge hated that. It still has problems in the center. Stationary subjects are obviously better. Most of the time it works seamlessly. I've never used anything else for comparison except Photomerge in Elements 6, which was much worse.
10-07-2012, 12:36 AM   #28
I don't know about LR or PS, but I used Microsoft ICE like ihasa and it worked fine for me. You may know ICE as photosynth on phones - ICE is the desktop version.
Speaking of tools that you can download for free - picturenaut is a pretty nice HDR tool, if you're interested in that.
+1
I also found that DA 15 shots stitch very well because of the lack of distortion.
10-07-2012, 07:12 AM   #29
THoog's Avatar
I've used the free open-source 'Hugin' stitching application for years, before I could invest in wider lenses. The early versions of Hugin were rather labor-intensive, but the latest is more plug-n-chug. As said above, to get a good stitch, it helps to have your camera on a support to limit parallax errors (tho' it's surprising how much the software can handle), and use aperture priority to avoid 'banding' in skies.
This is a stitch of Discovery from a half-dozen shots usiing a 18-50 zoom:
Discovery left side panorama | Flickr - Photo Sharing!
10-07-2012, 10:03 AM   #30
QuoteOriginally posted by THoog Quote
Well done!
da, f/2.8, fa, k-mount, kids, lens, lenses, pentax lens, pictures, shuttle, slr lens, space
Machinery Space Shuttle Endeavour Fly-Over Lupine Post Your Photos! 3 09-25-2012 09:30 PM
People Final Space Shuttle crew returns home rfortson Post Your Photos! 3 07-26-2011 06:41 AM
Machinery Space Shuttle Landing March 9,2011 tpeace Post Your Photos! 7 03-10-2011 09:37 PM
Misc Space Shuttle Discovery Launch 02-24-11 vievetrick Post Your Photos! 9 03-07-2011 07:14 AM
Misc Space Shuttle Launch tpeace Post Your Photos! 13 02-27-2011 02:45 AM
All times are GMT -7. The time now is 11:39 PM. | See also: NikonForums.com, part of our network of photo forums!
