Originally posted by Lowell Goudge i avoided answering this for a long time, not because I am a great photographer, just the opposite, I find that EVERY focal length is difficult
OK now that the fun response is out of the way, I think the bigger issue is that with zooms, you get lazy, and only use them at extremes for a very high percentage of shots. Often the middle gets left out, because you never position yourself to use the middle of a zoom, you are either too close, and back up just enough to frame at the widest FL or are too far and approach until you are framed at the longest FL. The problem is, you are never forced to look at anything other than the two ends.
I think the OP did not spend enough time at the focal length to start thinking in terms of only 30mm. nothing more and nothing less.
Don't get me wrong. I love my zooms too, but have also assembled both K and M42 MF prime kits, that I use when i am in control of the schedule, and are shooting for pleasure.
In K mount I have 8, 24, 28, 35, 50, 85, 100, 105, 135, 300 and 400mm
In M42 Mount I have 16, 24, 28, 35, 50, 55, 58, 85, 90, 105, 135, 200, and 300mm
I take them out, usually 3-4 lenses at a time, and shoot primes exclusively with limited focal lengths, and work on what I can do with each. do i have favorites, yes, but I shoot them all, and work with the focal lengths to learn how to see with each. it takes more than a week however. What I suggest the OP should do is pick up a cheap 28-35mm MF lens and learn how to see with that lens. He may then go back and get one he likes after he figures out uses for it.
It could be he is still in the same position, maybe the styles he shoots do not fit with the focal length etc, but the lenses have a use, it is just identifying how best to use it,
I wouldn't jump to assumptions so quick. I use my 16-50 all over the place. In fact on an exposure plot you see spikes at 16, 21, 35, 43, 44, 50, 55, 65, 68, 77, 100, 135, 120.
With the biggest use at 21, 55, 77, 135.
This is a polling of about 45000 photos.
I also find I shoot 2.8-2.0 unless in ultra low light.
Tells me I need a 21mm limited
