Hi lapeen & metalfab
So what do you make of the extensive range from wide 28mm to telephoto 375mm ? Is that IMPRESSIVE or WHAT, and danged sharp to boot.......!
Lapeen, when you said:
Quote: It's a lot heavier than I am used to
.....but surely a HECK of a lot lighter than carting two or three separate lenses around with you all the time !
I dunno, you just can't seem to please ALL the people ALL of time, can you.......LOL !
Best regards
Richard
P.S. Here's a useful tip ! Don't forget to leave the supplied lens shade
off when using the built-in pop-up flashgun at the wide 28mm end, or you'll end with unwanted shadows at the bottom of your photos......just a thought ! Incidentally, you can always attach the lens shade in reverse and then click it into it's 'storage' position on the lens. Simply line up the white 'dot' first, then
gently twist till it locks.
