Originally posted by mythguy9 Hi, I bought a K1000 months ago and is getting good photo from it using the standard 50mm f/2 Pentax-M lens.
I'd like to explore other focal lengths, so I'm asking for PRIME lens suggestions here. I might invest on Pentax digital system in the future, so the lens need to be non-DA standard, otherwise it won't be usable on my K1000.
After doing some research, I think for wide-angle I should start with a 28mm and for telephoto I should start with 135mm (so I'll have a prime for wide, normal, and tele each). I am a prime lens user and don't mind manual focus (I shot slowly). I'm not a particular fans for bokeh and rarely open up wider than f/4. For now I want to stick to low budget so old or third party lenses are okay too (screw mount okay too!). Aiming for price range 30-100USD including shipping.
I heard the Tokina 28mm f/2.8 is cheap and has reasonable performance. But I'm (very) open for other lens suggestions. Thanks.
p/s: add a few notes here...I picked 28mm also because the lens could act as a circa. 35mm equivalent on my future DSLR, so although 35mm lens is also wide-angle it isn't my first choice (becomes 50mm equiv. on DSLR and thus overlapping with K1000's lens).
The old classic standard kit for 35mm film shooters has always been a 28mm wide, 50/55mm normal and a 135mm telephoto. Most of us older forum members started with this kit way back when.
The K28/3.5 or M28/3.5 and the K135/3.5 or M135/3.5 are recommended, though the K28/3.5 might be hard to get for under $100.00.
Phil.
