Originally posted by gsrokmix
I know that there seem to be a lot more choices of lenses going the Pentacon-six route as opposed to either Pentax or Mamiya. Do you have any feeling as to the sharpness of the Zeiss lenses compared to the Pentax 645's?
None at all. I haven't used or even touched a 645 lens, however the ratings around here can be a guide, since some are used on digital bodies.
Practical comparisons are another thing, since I found many of the Russian and East German normal and wide lenses (45mm, 80mm, 110mm) to be soft on digital, whether tilted or not (naturally tilt means you're using the edges of the image circle, and wider lenses tend to do worse at the edges), so it completely depends on the lens.
I think the 645 75mm and adapter sounds like a good deal, since a P6 setup wouldn't cost you much less, and in the long run you can find more Pentax lenses via KEH and other reputable sellers, even here! (Pentacon-six gear tends to be sold via eBay from Ukraine, with little to no indication of the condition or quality of the lens.)
