11-07-2012, 12:55 PM   #16
Ikarus's Avatar
For scenery, it certainly is good enough for me, since I can usually stick to f/8 without needing a tripod. Different story in low light, of course.
Pentax K-x with Pentax DA L 18-55mm F3.5-5.6 AL @ 18mm, f/8, 1/640s, ISO 400:
11-07-2012, 02:20 PM   #17
QuoteOriginally posted by lytrytyr Quote
The DA 18-55 does a good job documenting things like signs for National Parks, but its rendering can be a little "muddy" at the fine detail level. Lack of microcontrast, as they say. There are some tricks you can do in PP, but they will only get you so far.
That's pretty much been my experience with the DA 18-55 II. The color rendition the kit lens is none to inspiring as well, which can have a real impact in landscapes. According to lenstip, the 18-55 blocks nearly 20% of the blue part of the spectrum from reaching the sensor. It's very hard to compensate for that in post without creating an over-saturated mess.
Any of the current constant aperture zooms, Pentax or 3rd party, would be a significant step up from the kit lens. And nearly any SMC prime lens, old or new, will give you even better results than most zooms. The best lenses I've used for landscapes are the DA 15, the K 28/3.5 and the K 35/3.5. The best zoom lens I've ever used for landscapes is the FA 24-90, which, between 40mm and 70mm, is prime good.
k-mount, lens, pentax lens, scenery, slr lens
which lens for me? wes k Pentax SLR Lens Discussion 10 09-03-2012 10:54 AM
Which lens for K30 Salacakli Pentax K-30 & K-50 15 08-13-2012 03:21 PM
Which lens adapter for Mamiya 646 and Pentax 6x7 lens popkrab Pentax Medium Format 2 02-21-2012 09:11 AM
Which lens for SF1 Kaufeetime Pentax SLR Lens Discussion 9 03-29-2011 10:01 AM
Which exposure mode for which lens? dosdan Photographic Technique 8 01-13-2009 11:09 AM
All times are GMT -7. The time now is 05:30 AM. | See also: NikonForums.com, part of our network of photo forums!
