11-08-2012, 09:34 AM   #1
Will Takumar lens work with any 49mm lens hood???
Will a takumar lens will work any 3-party lens hood (49mm)?
11-08-2012, 09:36 AM   #2
wtlwdwgn's Avatar
Which particular lens?
11-08-2012, 09:49 AM   #3
Pretty much, at least on APS-C, but I haven't seen every 49mm hood in the world.
11-08-2012, 09:49 AM   #4
QuoteOriginally posted by wtlwdwgn Quote
Takumar 1.4
11-08-2012, 09:54 AM   #5
oxidized's Avatar
Any standard lens hood of this type should be fine:
49mm Standard Metal Lens Hood for Canon Nikon Sony Z021 | eBay
However, on a cropped sensor, I would go for somethiing like that, using step up rings to 58mm
58mm 58 mm Tele Metal Lens Hood for Canon Nikon Sony Olympus Pentax Lens Cap | eBay
It would make the lens a lot bulkier, but for a non-coated Takumar it could be worth it. (I personally have not tested that but I have ready somewhere it should work). Maybe someone could confirm.
11-08-2012, 09:58 AM   #6
QuoteOriginally posted by oxidized Quote
I was thinking of going with a rubber hood or a flower type one, the takumar I have is SMC. What do you think? Should I go with the first one you mentioned or a flower type hood?
Also, my main reason for using a lens hood is to protect the lens, I'm really clumsy and I've already dropped a takumar lens and dented the filter ring in the past...
11-08-2012, 09:59 AM   #7
wtlwdwgn's Avatar
If you mean a 50mm f/1.4 most likely but then I haven't seen every hood out there either. I found a Pentax original on eekBay for not very much. Here's one at Adorama.
11-08-2012, 10:07 AM   #8
27$ for me is a lot! I could almost buy a new lens with that kind of money! I'm only looking to pay like 2.00, I don't mind if its cheaply built as it's only purpose will be to protect the filter ring.
11-08-2012, 10:12 AM   #9
QuoteOriginally posted by iNicole Quote
I was thinking of going with a rubber hood. Also, my main reason for using a lens hood is to protect the lens.
My SMC Takumar 55/1.8 wore a 49mm rubber hood for 30 years.
Cheap, great protection, and you can close in the hood a little by hand
if you need to shade from a certain direction.
11-08-2012, 10:14 AM   #10
oxidized's Avatar
In my experience, metal provides better protection than rubber. Thats why Ive always bought metal hoods. I really have no experience with the rubber ones. I would imagine their performance with flare reduction would be the same. It's really personal choice. If you have SMC coating then you should probably just go for the smaller and more compact one (first link).
Flower type hoods tend to be for wide angle lens and would not provide enough shade for a 50mm tak
11-08-2012, 10:23 AM   #11
wtlwdwgn's Avatar
You only get what you pay for.
11-08-2012, 10:25 AM   #12
You can find something on ebay for $5 that will work fine.
11-08-2012, 11:03 AM   #13
Lowell Goudge's Avatar
A long long time ago, I uploaded a spreadsheet called hoodcalc. It is I think still on the forum somewhere,
It can calculate the hood length, given (for non retro focus wide angle lenses) the front element diameter, and sensor format and hood diameter
11-08-2012, 11:07 AM   #14
https://www.pentaxforums.com/forums/attachments/pentax-slr-lens-discussion/46...d-hoodcalc-zip
k-mount, lens, pentax lens, slr lens, takumar, takumar lens
Will this lens work with my camera glentheduke Pentax SLR Lens Discussion 2 05-15-2011 12:12 PM
Will any old lens work with an adapter privateryan Troubleshooting and Beginner Help 5 12-14-2009 06:57 AM
For Sale - Sold: Takumar 49mm lens hood for a 35mm/F2 or 35mm/F3.5 with case SteveM Sold Items 3 11-24-2009 05:39 PM
Will another MFG's lens hood work on a Sigma Lens? dmoon911 Pentax SLR Lens Discussion 7 08-07-2008 02:02 PM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, part of our network of photo forums!
