11-11-2012, 01:07 PM   #16
audiobomber's Avatar
I was having trouble getting my K-x to focus reliably with MF lenses. I didn't want a split screen because of cost, potential metering issues and hassling with shims. I bought the Pentax O-ME53 magnifier from Pentax and it does the trick for me. Five minutes to install and I can focus the K-x as reliably as the the K20D now.
11-11-2012, 01:47 PM   #17
Na Horuk's Avatar
With my K-r, I can't tell critical focus in the viewfinder. Blame the OVF, or the bad eyesight, or whatever - it just doesn't work for me. I can tell the general focus, but not the precise focus. So I often either check in live view or after taking the shot. I like using catch in focus (CiF) with manual lenses, it tends to be fairly accurate, but keep in mind that the center focus spot is pretty big.
You can get a viewfinder enlarger or a focus screen or both, but I suggest you wait and try your lenses first. Maybe you won't need anything. The thing is, once you start messing with things like focus screen, you have a chance of messing things up.
11-12-2012, 02:19 AM   #18
If you have lenses faster than f/2.8, then you'll have to change the focus screen... Stock screens does not show actual DoF (and thus focus) with anything faster than f/2.4, so focusing a f/1.4 lens is tricky... Like doing needlework with boxing gloves, you can chance some points, you can even learn to master it, but it's quite hard.
I went from 40% to 95% success rate simply by changing my focus screen for a Canon EE-S (a blank screen made specially for fast lenses). Way better than a split, IMO, and does not mess metering (quite the contrary, in fact, it improves it!)...
Now badly focused shots are my fault only...
11-12-2012, 02:25 AM   #19
QuoteOriginally posted by dlacouture Quote
I have no trouble on my 55mm f2. f1.4 would be difficult, though, although not impossible.
11-12-2012, 03:40 AM   #20
will this canon EE-S focusing screen fit the kr? krs dont take the same sizenscreens as k5s. if not is there an equivalent size for the kr?
11-12-2012, 05:55 AM   #21
kh1234567890's Avatar
QuoteOriginally posted by cookiies Quote
This one would do it. Well worth buying it from focusingscreen.com rather than hacking it to size yourself. Comes with a shim kit, tweezers etc. On my K-7 it needs about +2/3 EV exposure tweak with any lens slower than about f/2.8, none with faster lenses. It is slightly darker than the stock screen but it really works.
k-mount, kr, pentax lens, slr lens, tips
Can I mount these Minolta lenses on my Pentax KR? cbeeching Troubleshooting and Beginner Help 16 01-17-2012 05:05 AM
Seeking advice on lenses for KR Cptn_Goodvibes Pentax SLR Lens Discussion 8 12-05-2011 03:44 PM
Thank you! New Kr. now where do I start for a full Kr body checkup? yanzhi0714 Pentax K-r 14 04-07-2011 05:54 AM
Lithium-Ion battery Vs AA Ni-MH on a Kr ide508 Pentax K-r 18 01-06-2011 04:00 PM
K lens on a KR mount Kambei77 Troubleshooting and Beginner Help 4 12-29-2010 11:25 PM
All times are GMT -7. The time now is 04:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
