11-14-2012, 05:52 AM   #1
mythguy9's Avatar
WR lenses against salt water?
Hi WR lens users, I might invest on WR lenses but I want to know if these lenses are resistant to salt water as well? I like to photograph the sea but salt spray carried by strong wind is a bit problematic...
Any comment?
11-14-2012, 06:03 AM   #2
nono's Avatar
I have the same question with an additional bit: are the seals of the DA* lenses better than the "plain" WR for this purpose? I'm not sure there's a difference between the two.
11-14-2012, 06:34 AM - 1 Like   #3
Clavius's Avatar
My setup has endured salt water sprays without any issue whatsoever. That said, I do take extra care afterwards. I whipe it down with some cloth and fresh water, making sure all the salt is gone. We all know what salt water can do to "stainless steel", and I'm not going to be the one to find out what it can do to my precious gear by leaving it there to do its work.
I don't know about the difference between the normal WR and te WR of DA* lenses though. It would be pretty weird if there would be any difference though. If there is a difference then it's a very wicked example of malperformance from Pentax when their WR-users are totally un-informed about that fact.
11-14-2012, 06:40 AM   #4
bdery's Avatar
There shouldn't be any problem with salt water, snow, sand, dust.
11-14-2012, 06:44 AM - 1 Like   #5
As a sailor, I'm all too familiar with saltwater corrosion. As Clavius suggests, you need to get salt residue out of every nook and crevice of your setup as atmospheric dampness is enough to keep the residual salt active and slowly turning aluminium to powder. Aluminium/stainless steel interfaces are particularly prone as they are dissimilar metals. If you expect to get hit with material amounts of spray, I would be considering employing one of those plastic camera/lens covers, and working on the WR being my second line of defense.
11-15-2012, 09:42 AM   #6
reeftool's Avatar
QuoteOriginally posted by southlander Quote
I will agree. I consider weather sealing a good protection for surprise conditions. If I know I'm going to encounter harsh conditions, I take measures to prevent as much exposure as possible to my camera and lenses and it really doesn't take much effort. A couple of seconds to cover things up will save you cleaning time later even if no damage is done. Salt water is very corrosive over time and affects everything it comes in contact with, even the seals installed to keep it out. It is also abrasive and will cause premature wear on any moving parts. Issues won't show up right away but rather several months to a over a year later. I am a fleet mechanic and have seen every form of "weather sealing" made and it all fails. At best, the weather sealed parts just last a little longer.
11-15-2012, 10:55 AM   #7
oxidized's Avatar
I have the DA* 50-135. I've shot on boats before. Water splashed on it a few times. I always took care of it and wipe it clean afterwards. Never had any problems. Cant comment on WR though as I haven't used those.
11-15-2012, 11:34 AM   #8
bdery's Avatar
QuoteOriginally posted by oxidized Quote
Your 50-135 is WR, you know
11-15-2012, 12:04 PM   #9
crewl1's Avatar
I've used the 18-135 WR on a K-5 earlier this year in the splash zone at Sea World.
I just rinsed the whole kit in the drinking fountain afterwards.
No issues.
11-15-2012, 01:15 PM   #10
mythguy9's Avatar
Thanks for all the advice guys!
Extra sealing and post-shoot rinsing, nice.
11-15-2012, 01:38 PM   #11
oxidized's Avatar
I am aware of that, but it is branded DA* not WR, and the OP had a question if the sealing was different between the DA* and WR lens.
11-15-2012, 01:56 PM   #12
Stone G.'s Avatar
QuoteOriginally posted by nono Quote
Yes, there is a difference:
DA* lenses are "dust and waterproof" and are more efficiently sealed than WR lenses which Pentax denotes as "simplified weather resistant".
11-16-2012, 12:52 AM   #13
Hmm.. My take would be, so long as your gear is within warranty, abuse it by using and keep washing it under tap water everyday... Everytime it "spoils", especially due to water leakage, just send it back to them. Of course, have a back up camera like a Kr or Kx..
Hey, it's as good as having free servicing for up to 6 years depending on warranty, right?
k-mount, lenses, pentax lens, salt, slr lens, wr, wr lenses
K30 kit lenses - WR or not WR? monochrome Ask B&H Photo! 2 05-24-2012 08:10 AM
water splashed on my non WR lens nirVaan Pentax SLR Lens Discussion 11 05-02-2012 07:31 PM
How WR is the kit WR Lenses Verglace Pentax K-5 5 05-16-2011 12:18 AM
K10D Protection against salt water environment Rnovo Pentax DSLR Discussion 7 07-01-2009 10:31 PM
Will Weather Sealed K20D & 50-135 resist salt water? HermanLee Pentax DSLR Discussion 9 06-10-2009 09:58 PM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
