Originally posted by Liamw Hi D0n,
I would need WR due to the high wind speeds I will probably encounter when shooting as spindrift/snow can find its way into the camera. Also most of my photography is mountaineering/adventure photography so it will be needed for this as well where water sand etc will be more prevalent. Manual focus won't really be possible with a big pair of gloves on i'm afraid due to temperatures.
Thanks for the reply.
my experience in arctic shooting is this... af fails. motordrives may fail, or tear film apart... or induce static spark light streaks on film.. film breaks... batteries die.
my experience was to use a k1000, sunny sixteen rule, wide angle m lenses set to hyperfocal distances and smaller aperture for DOF...
when using telephotos... zooms freeze up and jam. anything lubed will freeze up.... this includes shutters and lens apertures, so have all lube removed and replaced with something that won't freeze if possible....
uv filters for lenses.... and wear two pairs of gloves, pull the heavy ones off for shooting..
when I switched to digital for outdoor shooting here in Manitoba winter conditions... I found wearing an oversized outer jacket (ovre a lighter innner jacket) and keeping the camera warm inside it worked best... pull the camera out shoot and put it away again worked best... prevent it from freezing, even tape chenical hand warmers to the camera if possible..
I do not know if weather seals will become brittle and fail when cold, but if you keep the camera warm should not be an issue...
and applies to digital and film:
place your cameras in plastic freezer bags before bringing from outside cold to warm moist air inside and let the gear acclimatize or you'll get condensation in it...
