11-18-2012, 11:17 AM   #1
35mm zebra Flektogon - no auto switch problem
I have a Zeiss Jena 35mm f2.8 zebra Flektogon. The problem I have is that it has no auto/manual switch. When I turn the aperture ring nothing happens because the pin on the back is out and not in. There is a pin on the side which you can depress to close the aperture but it's hardly convenient - it's linked to the pin on the back.
I can imagine a solution which is some kind of adapter that covers over the pin and depresses it. Is this done?
Any other ideas?
11-18-2012, 11:28 AM   #2
QuoteOriginally posted by les24preludes Quote
Any other ideas?
Yeah, if you can remove the mount then you you can put a little sleeve (taken from an electrical wire, for instance) on the pin and then replace the mount and this will hold the pin down always so that aperture will open and close with movement of the ring. This is easily reverseable, but can also be risky because you are in danger of the mount falling apart, losing the little ball bearing that is usually in there to make it click, etc. Also some lenses are not easy to take apart in this way. Another solution is just to not take anything apart but just put a dab of super-glue at the base of the pin and then hold the lens pin down for a while to dry. That's usually what I do, also reverseable using acetone, but I have never tried to reverse it as I have had no need to...
11-18-2012, 01:20 PM   #3
There are M42 adapters that have a pin-depress feature, but they are hard to come by and quite expensive. The surgical solution may be your best option.
11-18-2012, 01:46 PM   #4
Lowell Goudge's Avatar
The adaptor you want is the bower one sold by B&H. It has a flange at depresses the pin, but be ware that this adapter needs a little surgery before use. The screw that holds the locking spring in place is usually too long and jams on the threads of your lens, and the spring itself is genially not the right shape and needs filing so it does not dig into the base of the lens whe screwed down tight.
Many people just remove the spring and be done with it.
Also this adapter does not work with many super tak's and SMC tak's that have the ability to work with spot attic F and SPII that have open aperture metering, because of a funny little bump on the tip of the lens.
I have modified all my auto only mounts using a 1/8 inch(3mm) piece of pen refil as the spacer. Depending on the lens no disassembly is required and I put a slit down the tube to ease removal
11-18-2012, 02:22 PM   #5
Lowell, I don't believe that B&H stocks that item any more.
11-18-2012, 02:24 PM   #6
That's too bad it has been a year or so since I got mine. There is a UK company also that makes one, I recall it being available when I got my bower one from B&H
Personally though I like blocking the pin with a sleeve.
11-18-2012, 02:30 PM   #7
No disassembly? How do you manage that? Usually there is no wiggle room whatsoever around the pin -- doesn't it need to get into or under the mount?
11-18-2012, 02:36 PM   #8
Some lenses have the pin exposed under the lens mount, in that case there is no need to disassemble. I had one such lens but on others, I took the mount off.
The tamron M42 adaptor also has no A /M switch, and can be modded without disassembly for the same reason
aperture, flektogon, k-mount, pentax lens, pin, slr lens, switch, zebra
Zeiss Flektogon f/2.8 Zebra Problem? burokas Troubleshooting and Beginner Help 4 08-06-2015 02:49 AM
For Sale - Sold: Carl Zeiss Jena Flektogon 35mm 2.4 m42 konradsiekierski Sold Items 5 11-13-2012 12:01 PM
For Sale - Sold: CARL ZEISS JENA DDR FLEKTOGON auto 2.4/35 MC PentaxMom Felua Sold Items 5 08-12-2011 12:40 AM
zeiss flektogon 35mm f2.4 problem rupi Pentax SLR Lens Discussion 7 08-06-2011 05:52 AM
For Sale - Sold: Carl Zeiss Jena Flektogon 20mm/4 and Tessar 50/2.8 Zebra style lenses farfisa Sold Items 3 10-09-2009 11:51 AM
All times are GMT -7. The time now is 02:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
