11-27-2012, 01:23 PM   #1
Modify old 500mm f8 to infinity focus?
Hi,
I just bought an old 500mm f8 lens (make is "Dufay" but think these are re-branded Paragon etc.) for taking pictures of the moon but it doesn't quite seem to focus to infinity. I've looked online and can't quite work out how to do this? I removed the M42 mount and attached a bayonet as the adaptor was increasing the distance between the back of the lens and mirror, this helped a bit but still not quite there.
Does anyone know how I can correct this? It looks like the front element can be moved onthe threads but haven't messed about with it yet.
Took it apart to remove some fungus out the back elements which cleared it a bit but think the fungus might have etched it a bit as still a bit hazy
Thanks in advance
11-27-2012, 01:38 PM   #2
Read this.......
https://www.pentaxforums.com/forums/general-technical-troubleshooting/173922-...ml#post1807361
Not the same as yours but may give you some ideas on how to adjust infinity.
11-28-2012, 05:48 AM   #3
Thanks, I had a look at the link you provided and then noticed I could remove three screws that hold on the distance ring thingy, I took this off and there was a screw that when I removed meant the helicoil could go down further which I think shold give infinity focus? Hopefully the moon will b eout again tonight and I'll give it a go.
Also found this link which I think is a similar thing for anyone else with the same problem:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/69759-500mm-f4...-infinity.html
Thanks,
Andrew
500mm, bit, f8, fungus, infinity, k-mount, lens, pentax lens, slr lens
80-320mm won't focus to infinity akptc Troubleshooting and Beginner Help 5 12-14-2012 08:46 AM
Using old screw mount asahi lenses wont focus to infinity??? carlyn.warnock Pentax SLR Lens Discussion 19 11-28-2012 10:24 AM
problem with focus to infinity vlad2304 Pentax SLR Lens Discussion 8 07-24-2011 05:49 PM
m28/2.8 - focus to infinity...and beyond John Araki Pentax SLR Lens Discussion 8 04-12-2011 09:33 PM
What does focus to infinity mean? justtakingpics Troubleshooting and Beginner Help 6 04-04-2011 01:04 PM
All times are GMT -7. The time now is 05:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
