Originally posted by HSV Let me see if I'm understanding this...let's say that you put a 50mm lens on a m4/3 body and a100mm lens on a FF body. If both are placed at the same distance from the subject, then the results will be equal?
Yes, this is correct. At least, it is theoretically correct (often what manufacturers list as focal length is not exactly precise).
Originally posted by HSV this mean that every lens can be a so-called portrait lens if I'm willing to crop? (without regards to other factors like DOF, resolving power, sharpness, noise, etc.)
Yes, you are correct, again. But that is very theoretical, and you would need to overlook most of the properties of lenses and sensors in order to operate in that manner.
One thing I have found helpful is to actually think in terms of field of view. I.e., when you look at something (from wherever you are), crop an image of it in your mind. Pay attention to what is in the crop (in your mind). Then, move closer or farther from the object, and do the same thing. You will notice the difference.
