11-29-2012, 02:09 PM   #16
Vindemiatrix's Avatar
QuoteOriginally posted by JinDesu Quote
It's not necessarily that the DOF is increased - you can see that my leaf shot, the in focus areas are still a little soft and bloomy, but my bench shot lacks the soft and bloomy-ness (specifically, look at the bench). And this has been true in my experience with using that lens.
Your 1.4 shot of the hose looks a heckuvalot more like missed focus - do you have any other samples?
@Gabro - the 1.6 shot isn't full size, so it's a bit tougher to judge, but it looks sharp. The DA*55 is supposed to be almost as sharp (or just a little sharp, sample variation) than my Sigma 50 - and I know my Sigma 50 is extremely sharp once stopped down to F2.8+
No is not missed focus it is really that soft at 1.4 in all light conditions, this is a 100% crop and the hose was about 4 feet away.
11-29-2012, 02:10 PM   #17
oxidized's Avatar
QuoteOriginally posted by Vindemiatrix Quote
here is a quick comparison shot. this is in bad bright sunshine 100% crops . first at 1.4 second at f8 as you can see there is no sharpeness whatsoever on the first shot,and it was on focus .
Given the harsh light, i think it looks okay. I would read this:
Pentax SMC DA* 55mm f/1.4 SDM - Review / Test Report - Sample Images & Verdict
according to the resolution charts the lens is rather soft at F1.4. Also your image looks very similar to the one he provided at F1.4. His might be "slightly" sharper but I think the harsh lighting in your example may explain the difference.
11-29-2012, 02:10 PM   #18
I'm sorry, I think I have mistake something, since I have not cropped the image! Try this All sizes | Muji | Flickr - Photo Sharing!
11-29-2012, 02:12 PM   #19
QuoteOriginally posted by gabro822 Quote
Have you made fine adjustments wide open (1.4)? Are those pictures made after the adjustments?
Yes the pictures are made after adjustments and the lens nailed the focus on both shots. It's just that is very soft at 1.4 .
11-29-2012, 02:13 PM   #20
Ok here 100% crop of a 1.8 shot. There is a great improvement from 1.4.
Hmm.. the 100mm WR Macro is definitely very sharp wide open, but my DA 55mm is extremely sharp wide open as well. In fact, I am convinced it is sharper than my 77mm & 31mm limited. It did need a -6 backfocus adjustment though....
Maybe compare shots taken through live view so that front or backfocus is ruled out?
edit: actually, looking through my photos, I don't have many at f1.4, most were at f1.8 so it's hard to say....
11-29-2012, 02:16 PM   #21
JinDesu's Avatar
Mmm.. if it's perfectly in focus, then seems really quite soft (or weak to CA) to me. Only issue I would have with that is - manual focusing is done in liveview with the lens wide open, so it may make it tricky to focus. Otherwise, I'd use it at F2 maximum...
Or get another copy >.>
I know my Sigma 50 1.4 is a bit bloomy wide open, but it definitely isn't as crazy as your hose crop.
I went to the sizes and chose the largest one. However, it's still not full size (unless your camera is 3MP )
You can do what Vindemiatrix did and crop the image (2000x1000 should do) and upload to flicker. However, even the downsized sample looks reasonable and not like Vindemiatrix's 1.4 shot.
11-29-2012, 02:37 PM   #22
I put the camera on a tripod and used live view av mode for these right here, results are the same not only in these but in all the shots I took wide open, indoors or out with good light or not.
First 3 are 1.4 1.8 and 2.2
second are 1.4 1.6 and 2
I just wonder if this is normal, or I should keep sending lenses back until I find the miraculous sharp at 1.4 da 55 lolz
11-29-2012, 02:40 PM   #23
I have set a +5 too on my k5. But in LV it it very sharp also at 1.6. Usually I don't use it at 1.4. Super sharp after f2.0.
But I have a question: is it possible that the 55 is sharper than the fa31? I have both and have this feeling.
If the 55 is sharper I am definetely not getting the 31
11-29-2012, 02:43 PM   #24
JinDesu's Avatar
The NV energy tag looks much more reasonable to me for 1.4. I guess the super harsh sunlight really throws the image out of whack. If the result is consistent to that energy tag at 1.4, it's pretty normal in my opinion.
I.e. - use F2 unless you can control the conditions for shooting =p
11-29-2012, 02:45 PM   #25
QuoteOriginally posted by Dirtistasty2 Quote
Great I am saving my cash by not buying the 77 and 31 LOLz. I was stacking this lens against the 43 ltd but I decided on this one for round bokeh at all apertures , I guess after all a 1.4 aperture is not really something very practical in everyday photography or something I absolutely need to use, but the whole thing of being so soft wide open just rubs me the wrong way I guess haha.
11-29-2012, 02:55 PM   #26
I am gonna find some time to compare it with the takumar 50 1.4. I am pretty sure as far as sharpeness wide open the tak performs better if not the same.
11-29-2012, 02:58 PM   #27
lol, It's a very very good lens, a bit overrated for me, but it does his job very nicely!
BTW, I think it's better for you to send this lens back, since it has clear problem! It wouldn't be like your 100 macro, but keeping a lens in this status is like throw your money!
11-29-2012, 03:01 PM   #28
PS. if you want I can make a shot for you at 1.4, but here in Italy is night, so I think that using flash would ruin the test... tell me if you want!
11-29-2012, 03:03 PM   #29
This is the my second copy. The first one was far worst. The aufocus wasn't right not even with af adjustment .
This one is far better but still not what I'd expect, not at big apertures at least. I recall my canon plastic fantastic sharper than this wide open and that's a lens that costs 6 times less.
11-29-2012, 03:20 PM   #30
Wouldn't that be because dof is increased at longer distances?.
Are you using a lense hood? If not, I would make sure to use one as it should help a lot in bright situations.
On my FA 50 1.4, I use a lense hood even when indoors. It helps the "sharpness" quite a bit.
My guess is that light coming in at different angles is what is causing the unsharp look.
Basically, pretty much any lense will produce better pics if used with a hood. The only real exception would be if it is a macro lense with a very recessed front element so that the lens housing itself acts as a hood.
adjustment, copy, k-mount, lens, pentax lens, slr lens
For Sale - Sold: Da* 55 1.4 Julie Sold Items 8 06-25-2012 04:49 PM
OOF comparison (FA43, A50/1.2, K50/1.4, FA50/1.7, DA*55, FA77,FA*85) dgaies Pentax SLR Lens Discussion 99 05-15-2011 05:43 AM
First shots from the new DA* 55 1.4 jsherman999 Pentax SLR Lens Discussion 29 02-22-2009 12:09 PM
All times are GMT -7. The time now is 06:39 AM. | See also: NikonForums.com, part of our network of photo forums!
