12-14-2012, 02:06 PM   #16
Racer X 69's Avatar
QuoteOriginally posted by sunglint Quote
The OPs old polarizer would be this kind. You put it on the camera and rotate it to get the desired effect.
Yes it is. It even has a handle for rotating it.
12-14-2012, 02:22 PM   #17
Anvh's Avatar
But circulair you also need to rotate so not sure why that is so special with linear one???
12-14-2012, 02:32 PM   #18
Racer X 69's Avatar
QuoteOriginally posted by Anvh Quote
Search me.
12-14-2012, 02:36 PM   #19
jatrax's Avatar
This is not correct. A linear Polarizer (usually a type PL) is a glass element that rotates on a glassless base, rotated to block the reflections from a certain direction.
I agree, what I meant was that in a CPL you rotate the two elements to get the desired affect with one element staying still and the other moving but with a linear you rotate the single element to get the desired affect. Linear polarizers usually have a notched edge to allow them to be turned or sometimes a lever. But my intent certainly did not come out correctly in that post. Sorry if I confused anyone.
12-14-2012, 03:16 PM   #20
You might also be missing modern coatings that are present on the nicer filters available today from Hoya, etc. These coatings will help stop reflections from filter elements. I think some of the Hoya ones feature SMC even. However, depending on the lens, that really won't hurt you too much.
film, filter, filters, gear, k-mount, lens, light, pentax lens, slr, slr lens
Using film lenses on dslr's? slackercruster Pentax SLR Lens Discussion 6 02-14-2012 07:47 AM
Using old lenses on digital SLR vinjosau Pentax SLR Lens Discussion 23 01-13-2012 10:42 PM
Adapter for using 645 lenses on 35mm SLR? LightMeter Pentax Film SLR Discussion 4 09-11-2011 06:24 PM
Turn your iPhone 4 into a DSLR using real SLR lenses interested_observer Non-Pentax Cameras: Canon, Nikon, etc. 24 08-02-2011 12:41 AM
Can I use my Dslr Pentax lenses on a film SLR? Billium28 Pentax Film SLR Discussion 25 10-19-2010 05:51 AM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
