Well then. Thanks to everyone for the input, and the quick lesson on filters.
I have always used some kind of glass to protect the front lens element, and keep from having to risk damage to it from periodic cleaning, and will continue that practice with the digital lenses. As for the polarizers, I'm thinking that even if the old film ones work, giving a newer type a go may be worth the added expense.
Great point about the post processing/pre processing decision. Once a decent image has been shot, it can be manipulated endlessly with the editing software of your choice.
As far as the lens hoods goes, I find I have to remove the hood on the 18~55 DA kit lens when using the camera's built in flash, or the hood creates a shadow in the image, even when using the flash for fill in daylight shots. But if I am not using a flash I always have the hood in place.
Originally posted by jatrax Polarizers come in circular and linear. The circular ones have two pieces of glass attached and you turn the rings to get the polarizing effect you want.
I have a Tiffen polarizer from the film days that has a handle to rotate it, to adjust the degree of polarization. So would that be the circular type?
Originally posted by jatrax Linear ones are a single element and you do not have to turn them.
Based on my understanding of light and how it is affected by a polarized filter (or even polarized sunglasses) rotating the glass in relation to the direction of the sunlight is how the light is polarized or un-polarized. So how would a single element polarizer be useful if it could not be rotated?
