12-02-2012, 07:19 PM   #1
jcdoss's Avatar
Long focal length limiteds
Why do you think the Limited series stops at 77mm? I'm a Pentax neophyte, but I expected to see Limited primes up to 135mm or so. Seeing a Limited zoom in the sub 50mm range on the roadmap seems to make less sense comparatively.
12-02-2012, 07:42 PM   #2
calsan's Avatar
DAs all share the 49mm filter size. That's probably one reason.
Another may be that there's probably little discernible advantage of a prime over a zoom in this range?? Just speculating.
Actually, the DFA 100 WR is often considered a limited by it's owners... and it's also 49mm.
12-02-2012, 07:56 PM   #3
Limiteds are designed to be very small, and it's really hard to make longer lenses that are small without sacrificing a lot of speed. And yeah, I would consider the 100mm WR macro a limited as they basically took used the DA limited design for it.
12-02-2012, 08:13 PM   #4
jatrax's Avatar
QuoteOriginally posted by calsan Quote
+1 I assume they called it DFA because it covers full frame but they could have called it Limited just as easily.
12-02-2012, 09:08 PM   #5
msatlas's Avatar
The F & FA 135/2.8 are nice & small but use 52mm filters. Not sure if Pentax could manage to make a modern Limited 135/2.8 and get 49mm filter threads. But since the F & FA were designed for 35mm film, maybe it'd work if only covering the APS-C frame?
12-03-2012, 02:19 AM   #6
Banned
Then there's the DFA 50 macro as well, same filter size as the limiteds
12-03-2012, 06:07 AM   #7
bdery's Avatar
I agree to that. If you want a longer focal length fantastic IQ lens, get the DFA 100 WR.
12-03-2012, 06:30 AM   #8
TenZ.NL's Avatar
Just wondering...if the DFA50 and 100 and also the FA77, FA43, DA35, FA31 are F2.8 or below, then why are the wide-angle LTD`s so mediocre fast?
I mean, why is the DA21ltd F3.2 and the DA15ltd F4? Is that due to the wide angle?
I would love to have a DA15ltd F2.8 or faster
12-03-2012, 07:42 AM   #9
audiobomber's Avatar
The DA*200mm and DA*300mm are not too shabby either.
12-03-2012, 08:12 AM   #10
bdery's Avatar
QuoteOriginally posted by audiobomber Quote
Of course. It depends on how long you want. On the other hand, those DA* are notwhere near as compact as what would (could?) qualify for a limited, I think.
Which lens fits in which category is full of gray areas of course...
12-03-2012, 08:51 AM   #11
QuoteOriginally posted by TenZ.NL Quote
As I understand it, limited size is part of the philosophy of the DA Limited range.
If you want an f/2.8 wide-angle in the 14-15mm focal length range, Pentax offers you the DA 14/2.8.
Since you can use really slow shutter speeds on wide-angle lenses with shake reduction,
I don't have a problem with the DA 15 Ltd being f/4.
In terms of blur avoidance, that's like f/2.4 at 35mm, or f/1.8 at 77mm.
12-03-2012, 08:59 AM   #12
But certainly not "Limited" size-wise.
If you want longer "Limited" telephoto lenses,
i.e. small and with a 49mm filter thread,
the Voigtlaender SL Apo-Lanthar 90/3.5 and 180/4 are as close as it gets,
although they are both manual focus.
12-03-2012, 11:06 AM   #13
bdery's Avatar
The 40 and 70 are quite fast, I'd say. But the DA limited seem to be focusing on size and uniform IQ, at the cost of aperture.
12-03-2012, 11:15 AM   #14
TenZ.NL's Avatar
QuoteOriginally posted by lytrytyr Quote
I know and the DA14 is allready in my bag but that`s not what I ment.
The interest is merely technical.
For example, the DA35ltd macro is F2.8 but it`s plastic counterpart, the DA35 F2.4 is allready faster with F2.4. Size of the filter is the same and I believe overall size too.
I have the DA35ltd and for F2.8 the frontelement is quite small, also the frontelement of the tamron 90mm F2.8 is small, only 52mm. But my DA14 and DA*16-50 are huge (77mm) compared to those.
The question was triggered by Adam`s remark:
To me it now seems the opposite:, the ultra wide angles poses more problems with faster apertures than wide-medium tele.
Also, if I look at my 35ltd, the filtersize is 49mm but the actual glas is only about 25mm while the frontglass of the DA14 and the DA*16-50 cover allmost the entire filterdiameter.
The DA15ltd also has some "flesh" left, i.e. the frontglass isn`t as wide as the (what`s it called?) barrel and that goes for most if not all limiteds.
Sorry if this turned into a wall of uncoherent text but english isn`t my native language
Crosspost...thanks for the explanation. But then it would be technically possible to design a faster aperture for the given sizes and shapes?
12-03-2012, 12:47 PM   #15
Just1MoreDave's Avatar
QuoteOriginally posted by msatlas Quote
The Pentax-M 120mm f2.8 shows that Pentax could get pretty close if you don't mind a bit shorter FL. It has a 49mm filter, slightly less diameter than the DFA 100/2.8 WR macro, and 20% shorter length.
k-mount, pentax lens, slr lens
Focal length setting lammie200 Pentax K-5 5 06-12-2012 01:51 PM
Inputting focal length? slackercruster Pentax DSLR Discussion 14 02-08-2012 02:26 AM
Resolution/focal length calculations lavascript Photographic Technique 7 12-28-2011 05:40 AM
Input Focal Length Butterfingers Pentax K-5 10 11-16-2011 11:30 AM
Focal length conversion JJD2500 Pentax DSLR Discussion 13 03-01-2011 05:30 PM
All times are GMT -7. The time now is 07:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
