you can use uv filer on sigma with
Fotodiox Introduces Two WonderPana Filter Systems, and its own Signature Line of High-Quality Filters for Professional Photographers
Fotodiox announces WonderPana 145 and 66 filter kits for wide-angle lenses: Digital Photography Review
The WonderPana Systems are available for pre-order starting today on the Fotodiox website and will be released October 15. The WonderPana 66 System starts at $350 and the WonderPana 145 System starts at $200.
Waukegan, Ill. – Fotodiox (
Fotodiox - your online source for professional photography accesories and supplies), a leading lens adapter and accessories manufacturer and distributor, today introduces the WonderPana 145 and WonderPana 66 Filter Systems. Designed to work flawlessly with the WonderPana Systems and compatible with others on the market, Fotodiox also introduces its new PRO line of ten neutral density filters. These ingenious lens filter systems represent the first products in the new “Wonder” line of original products planned for release by Fotodiox in the coming year.
Fotodiox’s WonderPana Systems are ideal for panorama, nature, architectural, fashion and event photographers, as well as analog and digital filmmakers who are looking to better manage lighting balance. A lens hood filter system designed for Super Wide Angle (SWA) and Ultra Wide Angle (UWA) lenses, they are compatible with the following lenses:
•Nikon: 14-24mm FX, 14mm FX
•Canon: 14mm Full Frame, 17mm TS Full Frame
•Tokina: 16-28mm Full Frame, 10-17mm APS-C
•Sigma: 12-24mm Full Frame, 12-24mm II Full Frame, 8-16mm APS-C, 14mm
•Panasonic: Lumix 7-14mm, micro 4/3 format
•Olympus: 7-14mm, 4/3 format
•Korea Lens (Samyang and various private label versions): 14mm Full Frame
