12-08-2012, 01:33 PM   #1
slip's Avatar
How are lenses made weather resistant?
How are lenses weather resistant?
Would most of the moisture get in between the lens and the camera mount?
Thanks
Randy
12-08-2012, 01:38 PM   #2
There's a rubber seal around the lens mount that prevents moisture from getting in, and similar seals located around every other opening. If you have any WR lenses, you can see the mount seal in action when the lens is mounted!
12-09-2012, 08:03 AM   #3
slip's Avatar
Thanks Adam
So it is possible with the right material to make a gasket to weather proof the lens to camera mount as long as its not effecting the electronic contacts?
Would have to be very thin and durable of course
Thanks
Randy
12-09-2012, 01:33 PM   #4
QuoteOriginally posted by slip Quote
Thanks Adam
Thanks
Randy
They disposable make plastic covers for your lens that cost like 50 cents- I'd go down that route if you want a quick-and-dirty solution.
12-09-2012, 03:47 PM   #5
Ex Finn.'s Avatar
Must be, because Pentax is doing it with their WR lenses .
Edit: for a DIY WR, use a zip-lock bag.
12-10-2012, 11:30 PM   #6
reeftool's Avatar
Most of us think of moisture when the subject of weather sealing comes up but dust is also a big problem. I've read several interviews with Nat Geo photographers and they always mention dust as the camera and lens killer when they travel to dry and arid climates.
12-11-2012, 05:56 AM   #7
bdery's Avatar
Indeed, with the right tools you could machine a groove on the lens mount's flange, and put in a gasket or o-ring of the correct size, then lastly dissassemble the lens and put similar gaskets at each open point... that would become tricky pretty fast, however
12-11-2012, 10:19 PM   #8
MSM
MSM's Avatar
just curious. For those that have telescoping WR lenses such as the 18-135 mm, can you still zoom when its raining or do you have to stick at one length? I am just wondering if water on the lens barrel needs to be wiped off prior to retracting the lens
12-12-2012, 05:58 AM   #9
bdery's Avatar
QuoteOriginally posted by MSM Quote
The general advice is to wipe the lens after you finish using it. I have a 18-55 and 60-250 WR and I just use them normally under difficult conditions, but when I'm done I extend them, wipe them, and leave them to dry completely.
12-12-2012, 10:30 AM   #10
slip's Avatar
Another idea would be to have the groove in the body so ALL lenses would be weather proof
thanks
randy
12-12-2012, 10:37 AM   #11
mrNewt's Avatar
And that's how cameras gets ruined and voided of warranty
12-12-2012, 01:17 PM   #12
bdery's Avatar
Only the camera would be protected that way, and then not completely. Lenses have many openings, especially zoom lenses, so water, dust, moisture could still get in and eventually ruin your lens (or gamera, if it works its way to the body).
12-12-2012, 03:54 PM   #13
MSM
MSM's Avatar
@bdery. Thanks for the info. I was worried that the zooming would introduce moisture but I guess that is what the WR is for.
12-12-2012, 04:05 PM   #14
amoringello's Avatar
Dunno how its done, but the barrel on the DA* 16-50 zooms in/out and I've had it unprotected in torrential downpours for upwards of an hour or more. The lens has been zoomed repeatedly while wet many many times over the past several years. It just works!
Of course, it was not until I recently had a simple repair done and the weather seals in the camera were damaged... at which point water from a very mild rain got inside the camera -- and then naturally Pentax will not cover the damage because "it appears water got inside the camera". No F'n kidding water got inside the camera!
I find it really odd that the camera was the one to fail first and in a mild rain, but the lens is fine after many wet days days.
Anyway, it would be interesting to know what magic they put in those lenses to keep out the dust and moisture.
12-13-2012, 05:08 AM   #15
Louicio's Avatar
What about the change in volume on a WR lens like the 18-135mm? How does it exchange air pressure with the atmosphere and still maintain its WR-ness?
k-mount, lenses, pentax lens, slr lens, weather
How Lenses Are Made reivax Pentax SLR Lens Discussion 12 04-21-2012 07:39 AM
Does anyone make Weather Resistant lenses other than Pentax? Balog Pentax SLR Lens Discussion 15 02-02-2011 04:41 PM
So, just how weather-resistant are the "Limited" lens climbertrev Pentax SLR Lens Discussion 10 11-17-2010 05:51 AM
How Weather Resistant are "WR" lenses? mediaslinky Pentax SLR Lens Discussion 7 07-12-2010 05:35 AM
WR Lenses- just how weather resistant are they? vk4akp Pentax SLR Lens Discussion 21 04-09-2010 08:06 PM
All times are GMT -7. The time now is 01:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
